Ej1 Help Not starting
Tried to turn on my car just a lil bit ago wouldn't crank over, fuel pump is kicking in but thats all I hear. I already checked fuses and grounds, any ideas what it could be?
Unplug the 2P connector from the starter switch at the top of the clutch pedal and install a jumper wire to connect the two terminals in the free connector. Put the tranny in neutral and then try to start the car (no need to push in the clutch pedal). If it starts, then the switch is probably bad.
A jumper wire is simply a short piece of wire with the insulation removed at the ends. Snugly insert each end of the jumper wire into the 2 terminals of the connector. This shorts the connector and bypasses the switch.
either a dead battery or a dead starter. You can remove either/both and take them to a parts store to get tested. I would try to push start your car first, if it runs you can take it to a parts store (leave it running) and have them put a tester on it that runs through all your electrical stuff and tells you if something is bad.
Okay, so we push started the car, had Autozone run there test. They said it was deffinatley not the alternater or battery (Which I figured). It could possibly be two things, bad starter or bad starter switch like RonJ@HT said. Thanks btw.
So Im going to remove my starter and have them test it.
rickkane
Jul 27, 2010 09:15 PM
