IACV Question
Old Jun 21, 2009 | 10:04 PM
eg grom's Avatar
Icon6 IACV Question
Wuddup Fellas,
I have recently been writting you guys about my dying d16z6 motor and have since replaced the rotor button, distributor cap, wires and plugs. Though you can tell that the parts were well needed it still seems that the car is not putting out like it should. SiRacer suspected that it may be the IACV and I plan on getting this checked out in the morning. I was under the influence that the IACV was the idle air controller, but it seems to be something different. Could anyone help me out in telling me more about this part and how I should go about getting it checked out? Any help would be greatly appreciated.
Old Jun 21, 2009 | 11:43 PM
medorihb's Avatar
Default Re: IACV Question
the IACV is the idle air control valve....what it does from my understanding of it...is it keeps a vacuum when the throttle body is closed so the engine idles....if you were to take it to the rev limit and let off, instead of it dying out the iacv controls how much air it lets in the intake and keeps the motor idling where it should until the throttle is open again...most the time you can take them off and clean them, and they will work fine.
Old Jun 21, 2009 | 11:49 PM
ek-g6's Avatar
I agree with^^^^ you can clean it out with brake or carb cleaner. If your z6 is not putting out I don't think the iacv does very much when in wide open throttle.
Old Jun 22, 2009 | 12:01 AM
medorihb's Avatar
yeah iac just controls the idle when the throttle body is shut....
Fnix
May 11, 2012 09:39 AM
g0tgot
Feb 1, 2009 07:27 AM
fe519
Nov 8, 2004 06:08 AM
hatch808
Jun 9, 2003 03:56 PM
ex voto
Dec 28, 2002 07:04 AM
