HELP...PLZ HELP ME OUT
Old Jun 21, 2009 | 11:08 AM
krujiente's Avatar
New User
Default HELP...PLZ HELP ME OUT
whats good HONDA-TECH i got a 95 4dr integra .. need help i swapped out my ls to b20 due to a blown ls now the car dnt wanna run good..runs weak n it choke when i rev...i bought new dizzzy,changed spark plugs,spark plug wires got a hondata gasket but b4 i changed it i sprayed starter fluid where the intake manifold gasket goes n it reved find ...mechanic told me it was cuz there was air leakin out dat was the reason it was chokin so dats y i went n bought the hondata gasket n tighten all the bolts but it still chockin...the other problem i got i dnt hear the fuel pump goin on sumtimes it does..i also change the fuel pump n yea i got gas.....n wat plugs must b connected so the car could run find cuz i got some plugs missing.........also where can i find the fuse or relay for the fuel pump
P.S plz help me out..or atleast bump it..... havnt had the car for a while due to dis
Old Jun 21, 2009 | 11:25 AM
krujiente's Avatar
New User
Default Re: HELP...PLZ HELP ME OUT
plz some 1 help me out.... i need help
Old Jun 21, 2009 | 11:33 AM
jdmcarboy2300's Avatar
what do mean by plugs.. u mean like sensors..??
Old Jun 21, 2009 | 11:39 AM
krujiente's Avatar
New User
yea the sensors
Old Jun 21, 2009 | 12:59 PM
Bwill9886's Avatar
You need to figure out and let us know what sensors you don't have hooked up because that could very well be the issue.
Sounds like it could be more but start with that.
Old Jun 21, 2009 | 01:05 PM
Pothole987's Avatar
You say that you don't hear the fuel pump everyonce in awhile? its not taking its fuel then maybe a bad connection in the ground for the pump, use a jumper cable to jump ground from the pump to the body to see if that helps. another thing could be the main relay crapping out on you.
Good luck.
Old Jun 21, 2009 | 01:06 PM
krujiente's Avatar
New User
do u noe where i can find the diagram for the engine hardness i been serchin but i got no luck was so ever
Old Jun 21, 2009 | 01:10 PM
krujiente's Avatar
New User
Good luck.
how can i check if the relay is badd???
Old Jun 21, 2009 | 01:21 PM
Pothole987's Avatar
find another one. or get a haynes manual to find out how to jump the plugin.
Old Jun 21, 2009 | 01:50 PM
krujiente's Avatar
New User
ok thanks
Old Jun 21, 2009 | 05:24 PM
give the relay some voltage nd if it works,, it will make a small click erytime u take it on and off
Old Jun 21, 2009 | 05:44 PM
krujiente's Avatar
New User
oo ok
Old Jun 21, 2009 | 07:35 PM
HondaGuy951's Avatar
if you just wanna swap longblocks it'll all bolt right into place.
4drint3gr4
Apr 9, 2010 11:23 PM
DA_9
Feb 9, 2008 09:41 PM
EG9-LSVTEC
Apr 9, 2007 09:32 AM
soon2b
Nov 3, 2004 07:48 AM
