FUEL PUMP QUESTION.
Old 04-09-2007, 08:54 AM
EG9-LSVTEC's Avatar
Default FUEL PUMP QUESTION.
I HAVE A 1994 CIVIC SEDAN WITH A B18B, AND B16 HEAD, AND I MY CAR HAS RECENTLY BEEN GIVING ME PROBLEMS. IT WONT START, I ALREADY CHECKED THE SPARK PLUGS, ALL OF MY INTAKE MANIFOLD LINES AND THE FUEL RELAY, IM ABOUT 90% SURE ITS THE FUEL PUMP, THE ONLY PROBLEM IS I DONT KNOW WHICH FUEL PUMP I AM SUPPOSED TO USE. THERE'S ALSO ANOTHER PROBLEM, IM A BROKE *** COLLEGE STUDENT, SO I NEED TO FIND SOMETHING EFFECTIVE AND LONG LASTING AND ABOUT AS CHEAP AS I CAN FIND IT. ANY SUGGESTIONS... WHERE CAN I START... ANY SHOPS??? HELP PLEASE.
Old 04-09-2007, 09:05 AM
EG9-LSVTEC's Avatar
Default Re: FUEL PUMP QUESTION. (EG9-LSVTEC)
somebody help... please!!!! my car has been off for a whole week, i am feening the adrenaline... i need to get this car running! help!
Old 04-09-2007, 09:09 AM
cute little bastard
SkoundrelUSA's Avatar
ok
1) Try not to use caps because people here just don't like it, unless you're actually are yelling
2) You gotta find out if its actually fuel you're not getting. It could always be spark, your igition, starter, battery, anything because you weren't very specific.
If the car cranks but doesn't start check out this thread.
https://honda-tech.com/zerothread?id=1320931
If it just clicks, check your battery, starter, ground wires
YoungKadafi's Avatar
holy! I never understood why people got pissed about cap's lock, i have seen the darkness.
Have you ever posted on a forum before? have all 15 of your posts been caps lock'ed from the back? Im so confused about this caps lock fornication! ITS FORNICATION!!! NON STOP FORNICATION WITH THE KEYBOARD! CAN YOU HEAR THE FUEL PUMP PRIMING? IF YOU CAN HEAR THE FUEL PUMP PRIME WHEN YOU TURN THE IGNITION ON FOR THE 1ST TIME @ STARTUP THEN YOUR FINE WITH THE FUEL PUMP, CHECK THE STARTER, GROUNDS. DO YOU DO YOUR OWN WORK ON YOUR CAR? CHECK FOR SPARK 1ST, DOES IT TURN OVER BUT NOT START? AS LONG AS YOU CAN HEAR YOUR FUEL PUMP PRIME YOU GOOD, IT WILL BE IGNITION THEN. CHECK TO SEE IF SOMEBODY TRIED MESSING WITH THE WIRES UNDER YOUR STEERING WHEEL
Old 04-09-2007, 09:22 AM
EG9-LSVTEC's Avatar
Default Re: (YoungKadafi)
i dont do work on my car by myself, I usually watch and assist my mechanic, im still learning. I recently got the swap so my spark plugs and distributor are new. I also checked them to make sure. I used a working fuel relay from another EG and it still didnt turn on. The car cranks but it doesnt turn on. And i had a problem before it totally shut down on me, when i would put the accelerated in, it bogged and it would die slowly, seemed like lack of fuel. Thats why i have a hunch that it will be my fuel pump.
Old 04-09-2007, 09:26 AM
cute little bastard
Default Re: (EG9-LSVTEC)
well if you really think its the fuel pump then you can use one from any 92-95 EX/Si or 94+ Integra. Or buy a new Walbro for $75.
Old 04-09-2007, 09:27 AM
very possible, but it could be your injectors too. Does the fuel pump turn on? lift up the rear seat and move the ignition to the II accy position, do you hear a HMMMMMM-CLICK. sound? if no, then your fuel pump is not turning on, and its your F-Pizzle. (suburbian for fuel pump)
If you do hear it turn on, then its your injectors harness or something, try another ECU.
Old 04-09-2007, 09:32 AM
EG9-LSVTEC's Avatar
alright. thanks fellas. although, the cheapest fuel pump i could find was a wahlbro one and it comes with an instalation kit for $100 shipped. Everyone else around here is elling them for like 150-200... Thanks for the help. We'll see how it goes, i'll check for the injectors...
Domnificent
06-30-2010 03:08 PM
Mref813
11
12-12-2009 01:35 PM
97elitehonda
12
09-29-2008 03:32 PM
lawlerlaw
11-16-2004 01:25 AM
Quick Reply: FUEL PUMP QUESTION.
