Clutch Pedal a lil soft even after bleeding
So after i bled my clutch and whatnot its still not as stiff as i would like it to be.i mean its ok right now, nothing is wrong, but i would like the feel to be a lil bit more 'tighter'.is there a way where i can tighten up something or adjust something to get my pedal to feel more hard/tighter? id like it to feel hard but not too hard where i need to the force of god to put it down.any help would be greatly appreciated.also pix would help that way i know what to look for
everything on the car is stock, its a 95 EG DX.nothing been messed with as far as the tranny is concerned just bled the clutch and changed the transmission fluid not that long ago.it uses a hydraulic system not the cable
On that old of a car, the clutch has been changed at least once so the clutch probably isn't stock. The pressure of the clutch pedal (when there are no air bubbles in the clutch line) depends on the pressure plate. The harder the pressure plate, the harder your clutch pedal feels when you use it. So they either didn't change the old pressure plate and it's now sloppy, or they put a soft pressure plate in.
If you want to replace the pressure plate you ask for a pressure plate. If you want to replace the clutch itself, you ask for a clutch disk. Or you can buy clutch kit which usually comes with pressure plate, clutch disk, clutch installation tool, and two bearings (input shaft bearing and throw out bearing). If you want your clutch to be stiffer you get a pressure plate with more clamping force than stock or whatever is installed in your car right now.
