Swapping GSR into RS (OBD2 to OBD1)
Old Jun 19, 2009 | 11:53 PM
sh4mr0ck's Avatar
Icon2 Swapping GSR into RS (OBD2 to OBD1)
I've searched... and I've read many many write ups on this, and I'm sorry for having another on here, but I'm extremely confused right now...
I'm swapping my GSR engine, which is OBD2, into my RS chassis, which is OBD1. I'll be using a P72 ECU.
If I'm right, my engine harness will plug right into the chassis, but I will need to wire for VTEC, knock sensor, and IAB... everything else is plug and play.
That being said, I just need a little help as to which pins I need to work with; below is an OBD1 pinout; I've never done a swap before, so please bear with me...
What pins will I be using here?
**Also, will I be able to use my cluster from my GSR, or will I need to find an OBD1 cluster?
Old Jun 20, 2009 | 08:06 AM
sh4mr0ck's Avatar
Default Re: Swapping GSR into RS (OBD2 to OBD1)
Will I just need to wire into A4, A17, A20, D3, and D6?
Also, would it make more sense to just use my OBD2 ECU with a jumper harness?
Old Jun 20, 2009 | 08:50 AM
DC206R's Avatar
Yeah a jumper harness would be nice. You have a OBD2 P72 right?
Old Jun 20, 2009 | 11:51 AM
sh4mr0ck's Avatar
I have an OBD2 GSR ECU, but I was planning on buying an OBD1 GSR ECU so I could plug it right into the stock harness, unless using a jumper would be a smarter idea.
mindless4banger
Engine Management and Tuning
Feb 28, 2016 12:50 PM
Rok_Stok
Oct 22, 2010 03:04 PM
sh4mr0ck
Sep 26, 2008 12:13 PM
zipperchamp
Dec 21, 2007 03:13 PM
screen_name
Apr 22, 2006 06:56 PM
