Classic Hondas All Pre-1988 Hondas.
New to hondas, please help!
Old Jun 18, 2009 | 05:48 PM
falkenfighter's Avatar
Default New to hondas, please help!
I bought a 86 Civic Si yesterday for $450, ive been working on it today pulling the main relay and the carpet out of the car. The fuel pump wont run so im thinkin the main relay is bad. i pulled the carpet because it is getting water from some place. i believe its coming from under the dash. i dried it out and then it rained and was wet again, i hadnt ran the car so i dont believe its the heater core. also the hood latch cable is broke, any ideas on how to get this open? any and all help will be greatly appriciated
as well if anyone knows of some cheap easy upgrades feel free to share, im looking to build this car to be 50% street 50% autox
here is the car, no rust
Old Jun 18, 2009 | 05:53 PM
78CITYTURBO's Avatar
Default Re: New to hondas, please help!
congrat on the SI. Could be main relay, maybe the fuel pump is bad too. Could be the ecu got wet, shocked. Good luck.
Old Jun 18, 2009 | 06:01 PM
well i plan on going to a junkyard tomorrow and pulling some main relays and maybe an ECU if they have a car of my vintage. i guess the main relays are the same up till 91?
Old Jun 18, 2009 | 06:48 PM
I have an extra main relay if you can't find one. I bought my car, non running, troubleshoot it, replaced the main relay, new fuel punp and new used ecu before I got it to run.
Old Jun 18, 2009 | 07:14 PM
the car has run, its done this a couple times and now wont start at all. the injection light doesnt turn on and niether does the fuel pump to prime the motor. the motor runs when it gets fuel
Old Jun 19, 2009 | 06:34 AM
ive never been a big fan of hondas, and my car knows it. i really really like this civic and would actually consider getting a newer hatch, but anyway on to today. this morning i pushed the car from my lawn to in front of my garage where instantly a screw went into a tire resulting in a flat tire, then i jacked up the front removed a splash shield to get to the hood latch which i got open by the way, then hit my head on the garage door a couple times before finally cleaning up that guard to sand blast and paint hopefully later tonight.
im gonna try to get a main relay or two today at a junkyard and call a guy that said he has a bunch of parts for 3g civics and 1g CRXs
so wish me luck
Old Jun 19, 2009 | 10:45 AM
cbstd's Avatar
Your Karma is very weak. I am betting that there were pushrods in your history.
This is a 20+ year old car, expect stuff to be wrong. If the previous owner had a lot of keys on his key ring, the ignition switch could be broken (a fairly common problem on these old cars).
As for the water in the car, it could be coming from the sunroof drain lines or from the air conditioning condensor drain which is under the glove compartment.
Scott
Old Jun 19, 2009 | 12:17 PM
E-AT_me's Avatar
i'm thinking AC condensor as rain. and don't bother buying a new relay, especially from the junkyard. take the old one apart and re-solder all the broken and cold solder joints and it will work just fine.
Old Jun 19, 2009 | 02:22 PM
well i got another relay, it was 3 bucks so i got it. i put it in and the light came on but no fuel pump so i took it out and put the old one in and it started right up, then put the new one in and it started right up. so i think i have that issue taken care of for now at least. im gonna mount that somewhere easy to access just in case. now a couple new issues, the fan doesnt come on so the car heats up really fast, ive shut it off before it gets really hot though. and im getting a surge in idle from about 700 and 1200 rpm, its a pretty rough surge. TPS sensor? vaccuum leak?
and yes my karma is bad but not as bad as you might think, rx7 then nissan sentra
Old Jun 19, 2009 | 05:29 PM
E-AT_me's Avatar
i meant drain tubes, not ac condensor...
check the coolant. sounds like a stuck thermostat or a bubble in coolant.
btw, that is a fantastic car man.
Old Jun 19, 2009 | 05:44 PM
how would i go about bleeding the system? the coolant boils so i dont think it is a stuck thermostat. the fan doesnt come on for some reason so that might be it so i gotta figure that out.
my junkyard doesnt have any 3rd gen civics or 1st gen crxs but they have some 4th gen civics, is alot interchangable between them?
you guys have been alot of help and i hope you guys dont quit on me before i quit myself
Old Jun 21, 2009 | 08:19 PM
old_jdmstyle's Avatar
New User
looks like a tidy SI you have there. I have a JDM one here in nz,first car and loving it. Hope you have fun with the build!
Old Jun 21, 2009 | 08:48 PM
well today i got alot accomplished, i reconnected my drain tubes for the sunroof after blowing them out with an airhose to make sure they werent clogged. then i drained the coolant and put a new fan switch in the bottom of the radiator and cleaned the system out by filling it with water, letting it run then draining it again. filled it up with coolant and seems to be fine now. i replaced the battery terminals because my positive one with the fuse and wire broke so i bought an inline fuse holder and put that in and cut the plug off and wired it together. so hopefully ill get the relay soldered tomorrow.
i drove it today and my clutch really is not good. i know all front wheel drives suck and since ive never done one it will suck even worse. ill have to save up to get a clutch kit, any ideas on which to get. i wanna get something good so i wont have to do it again
hopefully ill have her all put back together to go have inspected in the next couple days
Old Jun 21, 2009 | 11:36 PM
NW Classic Honda's Avatar
I want a white Si, nice come up!
Old Jun 22, 2009 | 04:50 AM
well if i cant beat this one into shape, then maybe you'll have the chance to own one
hahaha...maybe
Old Jun 22, 2009 | 05:45 PM
i fixed the fan yesterday and everything was fine so i took it for a drive today and it decided not to work again so i was stuck with a car that was overheating and i was 15 miles from home and im broke...
so i let it cool off then drove till it got about 3/4 of the way to H on the gauge then stopped and let it cool off and repeated 5 times. the last run it got hotter than the others.
to fix the fan i replaced the switch in the bottom of the radiator
any ideas on what it could be?
should i be worried now after tonight?
Old Jun 24, 2009 | 05:49 PM
well my head gasket is blown, and hopefully the head is ok...
i guess i need to get some money saved up to get a head gasket and timing belt and waterpump
how hard is that to do in these cars? looks kinda complicated
Old Jun 25, 2009 | 01:13 PM
2ndGenGuy's Avatar
It's ****ing easy. If you can't do a headgasket / waterpump / timing belt on a Honda like these, you might as well kill yourself.
Old Jun 25, 2009 | 01:25 PM
imzjustplayin's Avatar
Shouldn't this guy be using a multimeter before he starts replacing parts??
Old Jun 25, 2009 | 01:51 PM
i fixed the relay by soldering the connections. i was just curious about the difficulty of the headgasket change, im gonna do it either way
Old Jun 26, 2009 | 03:11 PM
Im curious if anyone on here is also on r p r?
I registered on there over a week ago and i cant do anything because an admin hasnt approved me or something? and because i cant do anything i cant message an admin to ask them why
any help would be appreciated
Old Jun 26, 2009 | 07:11 PM
E-AT_me's Avatar
what is the Screen name you used? i'm on there..
Old Jun 26, 2009 | 08:10 PM
its falkenfighter just like on here, im just assuming that it got missed or something but there is no way to contact anyone on there so i dont know
Dustin19902
11
Nov 18, 2014 12:34 PM
crxowner
Oct 2, 2007 05:49 PM
StreetEG
Jul 31, 2006 04:38 PM
Terrible One
Jan 5, 2006 07:49 PM
antivic
Aug 15, 2005 08:57 PM
