Fuel pump won't prime
the fuel pump won't prime sometimes I hear the main relay click when it's in the on position but no fuel pump then sometimes it will prime and no problems runs great need help thank you
93 Honda Civic fuel pump delay to prime
the fuel pump has a delay to prime sometimes. I hear the main relay click when it's in the on position but no fuel pump then sometimes it will prime and no problems runs great need help thank you
Re: Fuel pump won't prime
i just had this same problem. main relay went bad (cracked solder) replaced. still wouldn't start, so i opened the ecu and that was bad as well. so i had to replace both the main relay and ecu, now starts every time
Where did u get a new ecu from? And did it work fine when it was warm?
