Having idling problem with my B18C1 Engine
Old Jun 17, 2009 | 11:32 AM
Nomas04's Avatar
Default Having idling problem with my B18C1 Engine
What's up everyone!
I have a 2000 Honda civic SI and I just recently upgraded my B16 to a B18, but since then I have had very bad idling problems ranging from 1000 to 3000 rpm's. Can anyone help me out on this?
Old Jun 17, 2009 | 11:39 AM
Former User's Avatar
Default Re: Having idling problem with my B18C1 Engine
Is the CEL ON?
Have you checked for vacuum/intake air leak or cleaned the IACV? Is the throttle cable adjusted too tightly?
Old Jun 17, 2009 | 11:41 AM
EG6KILIN's Avatar
X2
Nomas04's Avatar
Sorry for sounding like a newb, but what's the CEL? The Iacv is clean, however I think it may have something to do with my cable because my pedal sticks a little bit when I drive.
Old Jun 17, 2009 | 11:43 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
check for vacuum leaks as Ron stated. Make sure there are no open ports on the manifold, I had a bad dile problem and there was a open line on the back side of my IM. As soon as it was plugged, BAM idle was perfect. And yea your throttle cable should seem awefully loose. Too tight can cause a leak.
Old Jun 17, 2009 | 11:45 AM
CEL = check engine light
Click here for more details.
The throttle cable should have 3/8" to 1/2" of free play.
Old Jun 17, 2009 | 11:48 AM
Nomas04's Avatar
Sometimes my engine light comes on, but then I when I take it to the shop my friends shop he sprays brake cleaner to check for leaks and the idling stops, but only for a couple of hours.
Old Jun 17, 2009 | 11:51 AM
Sounds like a vacuum or intake air leak. Pull the CEL code(s) from the ECU.
Old Jun 17, 2009 | 12:10 PM
if your pedal is sticking and your cable is at the right tension, then check the stopper on your throttle body, it may be screwed up too high...
Old Jun 19, 2009 | 07:46 AM
Nomas04's Avatar
***update*** 6/19
Just got another check engine light and the system is giving me the following errors:
P0171B Bank 1 system too lean
P0170 Fuel trim bank 1
This sounds like a vaccum leak. what do you guys think?
bk7794
13
Jun 21, 2012 08:17 PM
Spence
Apr 24, 2006 08:15 PM
White GSR '01
Jul 17, 2005 11:17 PM
vteckilla7
Aug 16, 2004 06:13 PM
DevinW
Jun 6, 2002 02:21 PM
