Sol won't turn-over.
hey guys, my car timing belt and water pump went bad like two months ago. I haven't had the money to fix yet. I left it sitting in my drive-way for a bit. I went out one day to start it up, but It didn't start. I can hear the fuel pump come on, but it won't turn over. If anybody has any ideas, please share it, thank you.
yeah..need alot more info.
so far it sounds like your timing belt broke and your water pump is leaking. you havent had the time to fix it so you let it sit until you get the moeny. you decided to start it up from sitting and now it wont start? hmm..i wonder if your timing belt being knowingly broken has anythign to do with this?
No the timing belt is not completely broken, it is just that time to replace it. My water pump needs replace that is for sure, because It's leaking coolant. My car still ran after I found these problems. I let it sit in my drive way till I get the money to bring it to a shop to fix it, but after I left it sitting there for a while it won't start. I knew the battery was dead after leaving it for so long but I put some juice back in to the battery and it still won't turn over.
Coolant can splash onto the timing belt when the water pump fails. This may cause the timing belt to slip, so check the mechanical timing.
With the key in ON(II), do you hear the fuel pump prime for 2 seconds? Do you have spark?
808k20a2
May 4, 2018 10:35 AM
eurodeseo
Dec 2, 2005 10:50 AM
