Help: cel 41 replaced 02 twice
hey guys, need some expert help from some of my HT buddies again.
I had a cel 41, primary 02 sensor heater. I replaced the 02 and reset the ecu. Started the car up a little more than an hour later and still threw cel 41. I've triple checked the wiring and all is good. Replaced the 02 again and same thing. I need some help as this has caused my car to run in "open loop" mode from what I've researched.
98 GSR - Turbo
obd1 jumper harness
tuned on hondata s100 (p06)
3" turbo back
Car ran absolutely Perfect until now. Its not my DD but I would like to get it back on the road. Any help would be greatly appreciated.
98 GSR - Turbo
obd1 jumper harness
3" turbo back
try getting your alternator checked out. i vaguely remember a similar problem with an integra when i was working at acura years ago. my boy was trying to fix a CEL for the o2 and one of the journeymen told him to check the alternator because if its not giving off enough voltage the o2 sensor wont get the right amount of volts and throw a CEL.
im not sure if that'll fix it but its worth a shot. GL
Dat1BVtecN
Engine Management and Tuning
21
Apr 8, 2009 07:03 PM
VTgringo
11
Aug 20, 2003 04:43 AM
turbotime
Jul 12, 2003 10:49 AM
