d16y8 and timing in hondata?
Hi i have a d16y8 top on a d16z6 block in my 96 coupe EX.
I have been running p2p ecu and e-manager fine, but i wanted hondata to tune some more.
The orginal p2p map and retarding timing under boost has worked good, but when i bought the s300 i did not know ther was no map for d16y8.
Should i take the p28(d16z6) map en retard the whole map by 4*?
I also tried to set timming at 12* and i flashed it to the middel line of the first 3
" ||| | " the crack wheel is also from my d16y8 block. when i do that i have to put the dizzy all the way back, but on the p2p i only had to have it on the middel so somthing is wrong.
With my original p2p i'm at 12* with the dizzy at center, to get the same result with s300 i had to adjust the timming to 21*.
So should i take the p28 basemap and add 5* insted of retard 9*????
Thanx for any reply
Kristian from Norway
Thanx for any reply
Anybody?
Any info.
What do you think of my base map?
Dizzy at senter were the orginal p2p ecu givs 12* ignition, but hondata needed to be base map at 21.5*
Any info.
Bump, I need to know too. I was outside messing around with my new s300 for the first time and the "Set timing" only allows for 16 btdc...is there a way to make it recognize 12 degrees for the y8?
to match the orginal p2p i have to have the timming to 21* And then the dizzy is almost in center.
I have been trying to figure out the same thing with a turbo D16Y8. Can anyone shed some light as to what is the best way to setup the ignition timing on a Y8. Should I be using a Z6 cam gear?
Does anyone have a S300 calibration for a STOCK Y8??
I have tuned plenty of y8 cars without issues with s300.
Sync the timing, setup the timing table as you would assume it should look like, put the car on a dyno & tune it.
Well after much research the best way to tune a Y8 is to use a Z6 cam gear and set the base timing to 16* like a Z6 or B series. Then you can use any of the P28 base maps provided with your tuning software and no need to mess with the timing tables.
Thats pretty much the setup I have and I cant get timing to match between the hondata ECU and the timing light. If I have dizzy all the way to the firewall I am still only at about 8 degrees of timing, when hondata says 16....
portenio78
Engine Management and Tuning
Mar 31, 2012 05:32 AM
