could it be the starter or ignition switch?? help!
ok so i got this 95 honda civic, when im about to turn the car on sometimes the car dosent turn on the first try, when i turn the key the car dosent do anything it dosent crank or anything, and i try it again and they it turns perfect without any problems and the car runs perfect...is the starter begining to fail? or maybe the ignition switch??
let me see if i explained my self correctly...i turn the switch and the car sometimes dosent crank or anything at all, i try a second later and it turns perfect????
question, i see that the check engine light is on for about 2 seconds when i put the car in accesories then it turns off...should i wait till that light turns off so i can turn the car on??
thanks for the help
thanks for the help
It could be the starter or ignition switch, but I suggest that you first check the starter switch located at the top of the clutch pedal. It's a common problem.
When you turn the key to ON(II) do your cluster lights light up or are they off? If they're off it's probably the ignition switch, if they light up then it could be the clutch safety switch like Ron suggested, otherwise it could be the starter solenoid (starter and starter solenoid are sold as one for 92-00 civics) or the wiring/connections.
Put the transmission in neutral. Unplug the 2P connector at the top of the clutch pedal and use a jumper wire to connect the 2 wires in the free connector. If the engine now starts without a problem, then adjust or replace the switch.
it would be easiest to just test the signal wire at the starter first. seeing as how you can hook up a voltmeter or test light to that in 5 seconds. if the solenoid is the culprit, then good, you've diagnosed your problem. because getting to that neutral safety switch can be a pain in the back of the dick, atleast it is on my car.
ok so today leaving from work the car didnt start at all.....it took about 20 minutes of trying and trying until it started....when i got home i shut it off and tryid to start it and it did start...but the same at before...i try to start it and no crank and the second time i do it it does start.....its the same thing every single time i try it...i try to start it and nothing and second time i turn the key broom it starts without any problem.. i tried to see where that security switch on the clutch is and dont really know where it is...
ok i found it....tried to take it off and failed lol...ill get a friends help tomorrow...for right now its starting ok...first time it dosend do anything but second time it starts perfect...
ok fixed it...i tested the clutch switch and was ok and test the starter and switch and was ok...so i found a old *** alarm in the car...it said 1997 lol...so yea the alarm didnt work but the cables conected to the main box....so took the box off and put everything back togueter and now it runs perfect....thanks to everybody that helped...
