d 16 block swap.
Old Jun 14, 2009 | 05:28 PM
ej6KRON's Avatar
Default d 16 block swap.
ok so i blew my old motor at the crank so i picked up a shortblock that has roughly 160k on it.
the reason why i bough the block was that my budget is SUPER tight and thats all i can afford.
ok so, the real question is how NECESSARY do i have to take it to the machine shop to get the crank and bearings replaced. for this new block..
nothing is wrong with the block itself.. just the dried up oil build up on top of the pistons.
so is it better to replace the internals that was damaged from my original motor with this replacement one...or..?? you tell me.
i drive the car alot. i take occasion trips to the beach, freeways and stuff and i gun it every now and then but its mostly from school work and home.
so please PLEASEE give me suggestions im not so good with motors.
thanks
Old Jun 14, 2009 | 05:33 PM
98civdx's Avatar
Master Detailer
Default Re: d 16 block swap.
well do to the miles i would re-bearing and ring the block and replace the seals and then it should be good to go in the car. dont forget to have them hone the block.
Old Jun 14, 2009 | 05:36 PM
ej6KRON's Avatar
estimation. just liek out of ur head.. how much would u think all that would cost. the replacement block was honed i saw the hone rings and it was preety legit. so tell me what i should do if i want to use my original block with the parts from the new block.?
Old Jun 14, 2009 | 05:39 PM
98civdx's Avatar
Master Detailer
what exactly happen to the old one? spun bearing?
i cant estmate the cost for the hone because all shops are different, and i get my stuff done for free...
but il look up some rings and bearings. shouldnt be to much.
Old Jun 14, 2009 | 05:48 PM
ej6KRON's Avatar
yea well i have a realy bad rod knock and then something broke and theres oil everywhere in my engine bay.. first thought was the head gasket..but never really knew. but my mechanic said spun rod bearing and maybe the crank is f***ed. cuz of how loud the knock is.
Old Jun 14, 2009 | 06:01 PM
98civdx's Avatar
Master Detailer
then no i would toss the stock block.
rings http://cgi.ebay.com/ebaymotors/HASTI...Q5fAccessories
bearings- http://cgi.ebay.com/ebaymotors/ACL-R...Q5fAccessories
and then just get a full oem gasket set.
Old Jun 14, 2009 | 06:58 PM
ej6KRON's Avatar
oh dam alright man thanks alot. i appriciate the info =]
Huee
14
Jul 10, 2007 03:22 AM
ge_itr
Jan 17, 2007 06:48 PM
AlienKrOZ
Jul 29, 2006 11:31 AM
JDM00SI
Nov 1, 2005 10:53 AM
EK99hatch
Apr 3, 2003 05:06 PM
