Can't do the compression test right ... ************
Do I use the 14mm long reach adapter? It says it's for 14mm long reach plugs only. I can't get any readings on the gauge.
Does the car have to be warm, first? My car kind of has a fugged up idle and ****.
What are the stock numbers for a stock block D16Y8?
I must have missed something....what adapter?? I always just pull the plugs, pull the 15A fuse(top left) in the underhood fusebox and push the clutch and gas all the way in, and wind it over about 7 or 8 times. Maybe you have a different kind of gauge or something, but the one that I have just screws right into the spark plug hole.
Yup u can do that or unclip the distributor...either works fine. And what adapter? Do u mean what replaces the spark plug?
Well, I do the test and once I do it a couple times, the car starts not wanting to crank. Do I just wait and do more later? or what?
So far so good.....
So far so good.....
What should I check? The battery seems fine to me. If it wasn't connected, then the car wouldn't do anything. This is so gay, I need to do the 4th cylinder then I can cry or rejoice. Arghh!
It'll crank for a sec and then stop. Then the starter just goes tick tick tick, etc...hmmm, maybe it is the battery?!
Uh, mine are consistent so it's not bad, right? RIGHT?!
My car is not starting. I can hear the starter ticking, but the car doesn't start. Is that a bad battery? All my lighting still works tho...
[Modified by OneCamTurbo, 10:45 AM 8/23/2002]
185 is perfect. I get something like 190-185-180-190 in mine. 220psi is WAY high on a stock D16Y8!
Oh yeah, it did have a Y8 head and gasket on it with the cam advanced 2 degrees
