High idle after TB clean up.
Old Jun 14, 2009 | 01:59 AM
Herzeleid's Avatar
Icon3 High idle after TB clean up.
Hi, HT crew.
Well... my momīs car was idleing real low. So, 3 days ago i disassembled the TB from the intake manifold to do a good clean up. I found that it was really dirty.
I used a tooth brush and some carb cleaner. I cleaned everything, I also disassembled one valve that goes bolted to the TB.
But... now the car is idleing at 1,500... steady. It remains at 1,500 and never goes lower than 1,000rpm.
I connected all the vacum hoses and installed a new air filter. Checked the tb cable, turned to the right the screw that is on top of the tb and nothing happened.
What could be the problem???
Old Jun 14, 2009 | 06:33 AM
madracer's Avatar
Default Re: High idle after TB clean up.
did you remove any of the sensors on the throttle body, before cleaning.???
Old Jun 14, 2009 | 06:36 PM
Herzeleid's Avatar
yes.
Old Jun 14, 2009 | 09:51 PM
Ya Digg's Avatar
got a new throttle body gasket right?
sounds like the other thing you took apart was the Fitv.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
this shows how to clean it and but back together correctly if you didnt.
look at #8 it shows how you should put it back in the right position.
Old Jun 15, 2009 | 03:36 AM
madracer's Avatar
your IAC might want a good cleaning or your tps sensor could be bad or need to be adjusted if you removed it to clean the throttle body.
The tps sensor need to be set at a set voltage on the throttle body, and should of been check before removing.
Old Jun 15, 2009 | 03:58 AM
pixelated's Avatar
x2 for FITV, be careful, when i cleaned mine i broke one of the 8mm screws that hold the plate on the side and now still have intermitant idle problems...
Old Jun 15, 2009 | 04:00 AM
pixelated's Avatar
oh and an easy way to tell if this is what is causeing it is, while engine is running there is a hole on the bottom left just inside the TB, use your finger to block it, if the idle returns to normal then you know its the FITV...
thewrai6th
Sep 13, 2011 05:19 PM
93del
Nov 21, 2010 04:28 AM
sevenfc
Mar 23, 2009 02:38 PM
92prelude23
Dec 13, 2008 11:47 AM
TallKyle
Jan 5, 2005 12:19 PM
