Suspension & Brakes Theory, alignment, spring rates....
6pot brakes will not stop
Old Jun 12, 2009 | 06:28 PM
1996h22a's Avatar
New User
Icon3 6pot brakes will not stop
I have rear drum and front disk brakes. For the front i have hp racing 6p calipers, pads, and drilled/slotted rotors. The company from what i understand will not sell pads and rotors anymore. My rotors and pads are worn down to where i should replace them but untill i can decide what to do they should still work.
I just had my rotors turned (because of rust) and now they are cleaned up pretty well, same with pads. Pedal for the most part feels pretty good, you can tell a slight improvement in it when starting the car (guessing master cylinder and booster are good)
so even with the rotors turned the car still stops poorly. Any guesses as to why? (Do 6p brakes usually require getting an upgraded booster?)
Old Jun 12, 2009 | 07:23 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: 6pot brakes will not stop
What car?
What brakes?
What are the brake piston diameters?
What are the brake rotor diameters?
Is the pedal hard or soft?
Old Jun 16, 2009 | 06:20 AM
1996h22a's Avatar
New User
its a 1996 honda accord
(Front)Disk Brakes: HP
(Rear)Drum Brakes: Stock
stock master cyl
Rotor Diameters: 310.21.46mm
Piston Diameters: ?
pedal firm, booster function verified.
Old Jun 16, 2009 | 05:39 PM
Dogginator's Avatar
Daisy... Daisy...
Can I assume that these once worked well?
Old Jun 17, 2009 | 07:11 AM
95greenlude's Avatar
talk about a huge braking imbalance....sheesh
Old Jun 19, 2009 | 06:43 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
1) u need a booster only cause you need a different master for the 6 pot, because our cars were not designed to have a 6 pot most stock calipers are only 1 cylinder with a 13/16master tiny, and since your upgrading to more cylinders their "area/diam" of the pistons are different sizes now, therefore requiring more fluid to press the piston to pad, pads to rotor, and your stock master may not be able to perform with those tasks.
-faded.....
Old Jun 20, 2009 | 05:02 AM
Dogginator's Avatar
Daisy... Daisy...
This is a good point. I assumed that these were intended for the car.
Kidnkorner
Dec 7, 2009 03:06 PM
speedfreek128
14
Feb 26, 2009 10:01 PM
2khb
Nov 6, 2007 05:06 PM
gringo7718
Nov 18, 2004 10:17 AM
