axle seal replacement.
Old Jun 12, 2009 | 12:15 AM
rea1ist's Avatar
Default axle seal replacement.
i need to replace my driver side axle seal for a B18b1, any one got a pic of the installation?? how far in do i have to push in the axle seal??
Old Jun 12, 2009 | 06:00 AM
SOHCNightmare's Avatar
Default Re: axle seal replacement.
Same question... in for answer.
Old Jun 12, 2009 | 10:03 AM
Cortez_h's Avatar
Here is a diy on a d series tranny to remove the axles but is pretty much the same steps on a b series just gotta unbolt the halfshaft and pop that out the tranny. The axle seal is right there once you take the axle and halfshaft off. Just pop it out with a flat head screwdriver and pop in the replacement.
You'll know if you pushed it in too far cause the axle won't go in all the way. Pretty easy to replace.
Axle removal diy https://honda-tech.com/forums/showth...ight=axles+diy
Old Jun 12, 2009 | 11:34 AM
yoontim23's Avatar
check the NEW FAQ'S INDEX - '92-'00 CIVIC / DEL SOL up top.
Old Jun 12, 2009 | 11:45 AM
NVturbo's Avatar
O.G. triple O.G.
Just take a visual or photographic picture of the old seal. If you look carefully, there is a limitation on how far you can push in the new seal.
Old Jun 12, 2009 | 12:54 PM
rea1ist's Avatar
how far in? cause the old one looked pretty far in, which is leaking.
i replaced it and installed it the same way and it still leaks a little.
anyone got a pic of how its suppose to look like.
Old Jun 12, 2009 | 01:32 PM
civic_driver's Avatar
http://www.raxles.com/CMFiles/Images...eal-1-copy.jpg
Old Jun 12, 2009 | 09:08 PM
rea1ist's Avatar
tnx but how bout the driver side?
Old Jun 13, 2009 | 06:16 AM
See if you can find it here somewhere: http://images.google.com/images?hl=e...&gbv=2&aq=f&oq=
But it should be similar to the passenger's side.
Old Jun 13, 2009 | 01:58 PM
rea1ist's Avatar
^ tnx bro but i tried searching it up but no luck..
bump anyone?
Old Jun 13, 2009 | 02:58 PM
Cortez_h's Avatar
bump anyone?
Have you removed the half shaft???
Old Jun 13, 2009 | 10:52 PM
rea1ist's Avatar
^ yeah i removed it to replace the axle seal but its still leaking a little
SlvrJdm
Oct 28, 2012 06:24 PM
jesssssss
Aug 1, 2012 07:13 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
See Are X
Oct 21, 2003 09:23 PM
