Cv Axle And Cv Axle Seal
i haven't taken out the cv axle out yet but if i did would i need to replace the cv seal? Also would it be easy to take it out and replace? What tool would i need for it? thank you
Re: Cv Axle And Cv Axle Seal
Buy new seals from Honda.
Remove axles. (It may help to drain the transmission fluid before you do this.)
Gently pry old seals out with a screwdriver.
Wipe clean the surface of differential contacted by the seals.
Evenly press each new seal into the differential, just until flush with the outer surface of the differential. I tapped the seals with a clean flat piece of wood to get them flush.
Grease the inner ring surface of the seal that contacts the axle and do the same on the matching surface of the axle.
Install new axles.
Install new axles.
bad news! before i can even start on the axle. My cv axle nut seem to be screw up it won't come out no matter what even if i use a torque wrench or a breaker bar it still stuck. what is my best option?
Go to your local tools store, and buy a 1/2" breaker bar. $15. Buy the 32mm socket. $3. To go your local hardware store, and buy a 3' length of lead pipe that fits around the breaker bar. Go to town on it.
