wheel bearing help. .
i need to know how to tell if wheel bearing is bad. i have a shake in my front end so i replaced my tie rods. ( 1 was bad ) i got a alignment and it was still there. so i put a new set of tires and wheels on thinking they were wore or out of balance. its still there. my right rotor is getting hotter then it should be. ( might burn you if you touch it ) but the rotor itsself isnt blue or burnt for a caliper being hung up.
it mainly does it around 50-60
raise your car, make sure your streeing wheel is locked, postion your hand at 6 and 12 o'clock...Then move up and down, if there is play you have bad bearings.
audiobyalbert
10
Jun 25, 2010 07:14 AM
