Experience with block seal and other similiar products
Old Jun 10, 2009 | 12:27 PM
my00SI's Avatar
Default Experience with block seal and other similiar products
I picked up a 00' Civic EX recently for $1000.00 which the previous owner had a busted radiator and she let it run hot enough to stop the engine, I was going to take the easy road first and replace the radiator and see if I could get the car running again and check for damage, so I replaced the radiator and put a pressure tester on it and its loosing pressure so there are leaks somewhere ; There is no coolant in the oil or exhaust, so before I drop in a new engine I was going to try one last thing and try a block sealer type product ( example below, ) what are yall's thoughts and can anyone recommend a good product to use ;
http://www.motorshop1.co.uk/sealup.htm
Old Jun 10, 2009 | 01:03 PM
RyanA's Avatar
Default Re: Experience with block seal and other similiar products
IMHO, they are temporary band aids at best. You need to find out where the leak is. If it's not going out on the ground, it's going into the oil pan or into the cylinders; neither of which are good places for coolant....
Do some more looking before you use a block sealer.
Old Jun 10, 2009 | 01:59 PM
98civdx's Avatar
Master Detailer
^^ i agree, look around before pouring crap into your car.
Em1Dustin
Aug 15, 2018 10:37 AM
92blm92
31
Nov 7, 2017 03:48 PM
inland180
Mar 27, 2007 10:56 AM
ShinobiLude
Nov 19, 2005 08:34 AM
918-Hatch
Feb 21, 2005 10:20 AM
