93 del sol no start
I have a 93 del sol s with what looks to be a d16z6 block and a d15 non vtec head. It had a aem cam gear on it and had to take it off to pass smog. So I just loosened the gear and slide it off and then slid the stock one on in the same place or so i thought. Now the motor just spins. I have spark and fuel in the motor. I pulled the the whole thing apart and set the crank pulley to tdc or what the repair manual shows as tdc. and i have the stock cam gear at tdc with the word up at the center and the lines parallel with the head. I need help cause I need the car to be running asap. Thanks
the wires and injectors were never moved. and i did as the book recommended and spun the crank 2 revolutions to make sure nothing hit. Could the valves be to high? I will run a compression test now.
Brockasaurus
Nov 2, 2011 06:41 PM
AaronGeisinger
Dec 11, 2010 05:15 AM
