how to clean AC fan inside cab?
Old Jun 7, 2009 | 04:36 PM
turbo_b16_ex's Avatar
Default how to clean AC fan inside cab?
OK boys, so Im going to repair my AC tom. Heres what I plan on doing:
- Renting vacuum pump, get refrigerent
-repair leaky tube from condensor to accumulator
heres my questions,
is it safe to run a leak finder?
whats the best refrigerant to run to get it super cold? - i dont plan on keeping the car long, so should i go ahead and do r-12?
how do you clean the inside condensor thing, my cars a 99, im sure its dirty.
My compressor is dry, how much oil do I run?
Whats a good high/low side pressure?
Thanks for reading, any insight will be extremely helpful!
Old Jun 7, 2009 | 04:49 PM
Former User's Avatar
Default Re: how to clean AC fan inside cab?
If you have a stock 99 Civic, then you have no choice but to use R134a refrigerant.
Low side - 23-36 PSI; high side 240-300 PSI
Old Jun 7, 2009 | 06:54 PM
yes i do have 99 civic.
Old Jun 7, 2009 | 07:17 PM
Welfare's Avatar
Take it to a reputable shop and have them do it for you, That way they can run the leak detector and be responsible for any problems down the road, they will also know how much of everything to put into the system.
Getting at the evaporator (inside condenser thing) is a pain and I personally wouldn't even bother, it's prolly not as dirty as you might think. Cleaning it would involve removing it, along with your entire dashboard, not fun.
Old Jun 7, 2009 | 07:26 PM
TheJGB3's Avatar
It is strongly recommended that you change the accumulator/receiver drier ANYTIME the A/C system is opened up for a leak repair.
As for cleaning the evaporator core in the dash, Just blow it out with compressed air (there will be a lot of leaves, pine needles, dust, hair, fuzz, etc. in there) so cover your front seats with bedsheets or towels first. Remove #6 in the parts view below (this is where the A/C filter would go if you had one and you can install a 97-01 CR-V one if you want).
Parts
Cabin Air Filter Parts*:
- '97-'01 CR-V / '00-'06 Insight Cabin Air Filter
--- US Honda Part No.: 80291-ST3-E01 - List: $21.98
--- EDM Honda Part No. (Civic): 80291-ST3-505 - List: $21.98
--- Bosch Part No.: P3753 - List: $19.99
- '97-'01 CR-V / '00-'06 Insight / '96-'00 EDM Civic Cabin Air Filter Frame
--- Honda Part No.: 80292-ST3-E01 - List: $13.74
* I'd recommend you purchase these parts all separately instead of as a full filter assembly. The list for the full assembly is $55.93, while the parts separately which make up the assembly cost a total of $39.25 for some reason.
Read NOFX's DIY here
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-cabin-air-filter-1998-2000-civic-2112319/
Old Jun 7, 2009 | 10:08 PM
TheJGB3's Avatar
OOPs double post!
EJ8CIVIC
Aug 3, 2015 12:00 PM
Nisif
Jul 16, 2012 06:05 AM
greg51
18
Jun 8, 2011 01:02 PM
Muckman
Jun 1, 2011 10:59 AM
KGNickl
May 1, 2008 01:59 PM
