ring lands and piston rings
Old Jun 6, 2009 | 03:59 PM
rudedawwg's Avatar
Default ring lands and piston rings
what are the signs symptoms of a cracked ringland and/or ****ed piston rings other than bad compression???
Old Jun 6, 2009 | 04:07 PM
mattliston's Avatar
Default Re: ring lands and piston rings
vertical scratches when you take apart the block :dunno:
Old Jun 6, 2009 | 04:09 PM
.dave's Avatar
i HAS questions ?
Is there any smoke coming out of the breather?
Old Jun 6, 2009 | 04:22 PM
D16SiHatch's Avatar
blue smoke out your exhaust would indicate muffed up piston rings
Old Jun 6, 2009 | 04:23 PM
mattliston's Avatar
oil burning? that could also be leaky valve guides/seals, which are very common on hondas if they burn/use a lot of oil
Old Jun 6, 2009 | 08:09 PM
rudedawwg's Avatar
i believe its blue but its kinda hard to tell from looking in the mirrors
just had the valve seals replaced thinking it would solve some of my blow by problem but it didnt.... so my catch can still smokes like a sum bitch. theses pics are from idle
Old Jun 6, 2009 | 08:14 PM
EGR95's Avatar
hey...bro i have the same problem with my b16a. when i start my b16a little smoke comes out, but i don't were? and this happen when i install a new oil pump?
Old Jun 6, 2009 | 09:59 PM
EK2.0's Avatar
Do a leak down test. Then you will know where your compression leak is!! just make sure you do it at TDc on the correct stroke!!
LaOXXKIDD
Aug 15, 2009 12:05 PM
ianp3k
Apr 24, 2008 12:05 PM
H9Omega
16
Dec 14, 2006 06:28 PM
Chuji
Aug 19, 2003 02:06 PM
tominos
22
Feb 18, 2003 08:55 PM
