whats better p28, or p72?
Old Jun 4, 2009 | 12:19 PM
spoolinNpullin's Avatar
Default whats better p28, or p72?
I need to know what ecu is better a p28 or a p72 I have 2 and I want to sell one so I want to keep the better of the 2
Old Jun 4, 2009 | 12:21 PM
R666_EK's Avatar
Default Re: whats better p28, or p72?
What motor you running? Plans for a tune? The p72 obd1 or obd2?
yoontim23's Avatar
P28, because you can chip it.
Old Jun 4, 2009 | 01:12 PM
sorry it's a ls vtec with skunk 2 stage 2 cams dual valve springs, valves, skunk 2 intake manifold, walboro 255, type r header full exhaust with cat, and a couple of other things, I will be putting a vafc in it soon, and everything is obd1.
Old Jun 4, 2009 | 01:26 PM
B18CivicEJ8's Avatar
OBD1 P72 ecus can be chipped, as well. That's why R666_EK asked what OBD version the P72 was.
To OP: if you are running the skunk 2 manifold, obviously you don't need the P72 cause you removed the IAB. Instead of wasting your money on an crappy VAFC, get the P28 chipped and then you can have someone do a custom tune on your car. It will perform way better than a VAFC.
Old Jun 4, 2009 | 01:37 PM
R666_EK's Avatar
Yes. That's EXACTLY what I was getting at. Well put.
Old Jun 4, 2009 | 02:12 PM
cleansi's Avatar
x3 vafc=crap
Old Jun 4, 2009 | 02:19 PM
pvt_awol's Avatar
agreed. Not sure why you would chip an ECU, AND run a VAFC....
I vote P28. It will do all the same stuff as the other ECU once you chip it, and you can sell the P72 for a bit more money.
Old Jun 4, 2009 | 07:44 PM
thanks guy's, how much do you think I can get for the p72, and where is the best place to send the obd1 p28 to get it chippped,
Old Jun 4, 2009 | 07:52 PM
tkda's Avatar
xenocron.com
custom basemap and you will proly run alot better already.
Old Jun 4, 2009 | 08:37 PM
thanks guy's
Old Jun 4, 2009 | 08:49 PM
.dave's Avatar
i HAS questions ?
I second the Xenocron suggestion. Also, you might want to look into having him chip your ECU and tune your car at the same time. He is located in New Jersey.
Old Jun 5, 2009 | 11:07 AM
CIVICZERO18's Avatar
New User
p28 all the way
Old Jun 5, 2009 | 11:22 AM
skipbudlong's Avatar
can you elaborate on the vafc?
Old Jun 5, 2009 | 11:33 AM
http://www.importperformance.com/ape...criptions.html
http://www.turbomagazine.com/tech/01...afc/index.html
Back in the '90s, before Hondata, Neptune, Crome, and www.phearable.net, people who wanted to edit their air/fuel ratio and VTEC engagement points used piggy back computers made by APEXi to do the job. These piggy backs go in between your ECU and various sensors on your engine. They would intercept the electrical signals and give the ECU a different signal in order to fool it into dumping more fuel, or to engage VTEC earlier or later. These are now pretty much obsolete because you can chip and custom tune P28 ecus to have correct fuel and timing maps throughout the entire RPM band. A chipped and custom tuned ECU is much safer and way more reliable then intercepting signals to fool a stock ECU.
Old Jun 5, 2009 | 03:57 PM
LOVEthatDC2's Avatar
sell me your obd1 p72
Kiniku Chunks!!!
Aug 28, 2006 10:51 AM
sal_blkej2
Feb 16, 2004 06:45 PM
vizsual00
18
Oct 23, 2003 02:33 PM
StinkyTofu
Apr 15, 2002 01:12 AM
