WILL THIS HARNESS WORK???
Old Jun 4, 2009 | 06:58 AM
hannslebo's Avatar
Default WILL THIS HARNESS WORK???
http://atlanta.craigslist.org/pts/1166163431.html
i am swapping motors. I just got my (JDM)b16a2 and since its jdm the engine harness is backwards. so....will this harness that i have linked above work???
thanks in advance.
Old Jun 4, 2009 | 07:06 AM
hannslebo's Avatar
Default Re: WILL THIS HARNESS WORK???
Old Jun 4, 2009 | 07:17 AM
jamelin's Avatar
dont think so but im not 100% sure..just find the b-series harness you need for your b16 engine
Old Jun 4, 2009 | 08:54 AM
hannslebo's Avatar
am i able to take out the jdm engine harness that is backwards...is there any way i can "re-wire" it to fit my USDM chassis harness.
Old Jun 4, 2009 | 09:06 AM
Jdm Mizz's Avatar
You Actually Need Both Harness If Its A Jdm Engine.. Both b16 USDM and JDM And Cut The Ones You Need. Im 80% Sure
Old Jun 4, 2009 | 09:12 AM
B18CivicEJ8's Avatar
What car is this going into? It's way easier to use your existing harness and add wires as needed. There is no easy way you can re-wire the JDM harness.
Old Jun 4, 2009 | 10:02 AM
Anton LaVey's Avatar
this is dumb yes you can use the harness on craigslist but you would have to wire in vtec yourself
Old Jun 4, 2009 | 10:08 AM
Ryank327's Avatar
Thats a D-series Harness. You have a B-series...
Old Jun 4, 2009 | 10:25 AM
lluks_844's Avatar
D series and B series harness's are interchangeable.
Use the harness that came with the car.
Old Jun 4, 2009 | 10:59 AM
goldfinger93030's Avatar
just find the plugs you need and mod you the harness you have already if it isnt a b series
Old Jun 4, 2009 | 11:20 AM
hannslebo's Avatar
so even if i got all the plugs plugged in on the engine and into the plugs under the hood... will the engine run right????
Old Jun 4, 2009 | 11:26 AM
jamelin's Avatar
prob not unless ur really good at wiring..just save yourself the hassle and buy the b-series harness for ur b16, it plugs right up and you dont have to worry about you motor starting up
Old Jun 4, 2009 | 12:24 PM
R666_EK's Avatar
Since you have an EG you can either get a GSR EWH or modify the harness you already have. No sense in buying another one not wired for VTEC either.
UniqueX707
Nov 24, 2014 11:33 AM
Jimmii
Apr 9, 2009 06:54 PM
ej1_jdm
Dec 5, 2005 01:11 PM
nutsack
Oct 26, 2003 05:04 AM
cmk804
May 9, 2002 03:16 PM
