Z6 harness into a dx
Old Jun 4, 2009 | 04:06 AM
93boostedz6's Avatar
Default Z6 harness into a dx
Ok so i built my engine droped it in with out issues its a d16z6 . So i get it all together and i get spark fuel and i have good compression but i have a check engine so my question to you guys is the z6 engine harnes not compatable with the dx chasis harness should i reuse the b7 harness any info would help thank u
Old Jun 4, 2009 | 04:40 AM
Default Re: Z6 harness into a dx
Ohh and it wond start either
Old Jun 4, 2009 | 05:24 AM
weavertime1's Avatar
if it won't start then there is no way you are getting consistent spark and fuel. That harness will allow the car to start and run fine, but you will have a code for VTEC once you run the engine above the point where VTEC would engage. Also, if you have a check engine light at this point, use a paper clip to jump your service connector and pull the code by counting the number of long and short flashes your check engine light gives off. Long flashes = 10's short equal = 1's When you figure out your cel issue, wire VTEC from your ecu to the shock tower to get VTEC. Good luck!
Old Jun 4, 2009 | 05:34 AM
EJ1_Ex's Avatar
the z6 harness will fit. The only plug that wont have a spot is vtec. Check your grounds
Old Jun 4, 2009 | 05:39 AM
True but some of the pins from the z6 harness do not match the chasis harness of the dx at the shock tower so i figure if it is not getting some sensor feedbacck it wont start correectly
Old Jun 4, 2009 | 08:43 AM
Yes, it's the VTEC solenoid and VTEC pressure switch, neither of which would keep your car from starting. Good luck!
Old Jun 6, 2009 | 08:04 AM
ok soo update i got the thig to attempt to start by putting on my b7 harness and it just wont turn over do you guys think its a wiring issue or my fuel map is of and im gettin g too much fuel
Old Jun 7, 2009 | 09:30 AM
What did you do to "build" your engine? At this point there could be multiple issues with the engine. Also I promise that the B7 harness did nothing...it must be some other issue that was fixed when you installed the B7 harness. Who knows, maybe the Z6 harness itself is messed up.
Taylor Mcalpin
Engine Management and Tuning
May 13, 2017 04:43 PM
Jay_Mills
Jun 29, 2011 09:29 AM
Djungle27
Mar 9, 2009 08:18 AM
capbyrd
Oct 14, 2004 12:34 PM
