Car hard to start in the Morning ..Help !!
90 civic ef
hard to start in the morning or when it sits there for a while ....but after it turns on everything runs fine !!! need help thanks
What do you mean it's hard to start? Like the motor turns over slowly or does the starter just click? or the car turns over but just doesnt start up?
No cel when i start car but after a while of drive and car and motor is hot the lights comes on...tune up is okay new spark plug oil change new fuel filter fixed fuel evap...main relay is fine ...maybe the ignator ?? or starter ?
just out of curiosity, which engine and ecu do you have?
at first i thought you had an obd0 setup, but after seeing code 23 come up i'm guessing your running obd1?
Well, there's your answer. It's hard to start because you're running untuned and dumping in 1.6L worth of startup fuel plus cold-cranking enrichments and you're only running a 1.5L.
Try cracking the throttle a little bit next time you start it cold (maybe 5%), it'll probably start more easily.
ef9_pr0jekt
Mar 7, 2020 07:44 AM
mister.wong
Sep 13, 2008 04:45 PM
slowmotion4x4
Jun 11, 2008 07:21 PM
