96 hatch with jdm b16 and p30 ecu question
Old Jun 1, 2009 | 09:50 PM
autoponicz's Avatar
Default 96 hatch with jdm b16 and p30 ecu question
hi...hope this is the right place to post this...
but i have a 96 hatch with a obd1 jdm b16 and the jdm p30 ecu .
im wondering if i need to rechip the p30 ecu since its already meant for a b16..
how different is the basemap on the jdm ecu's compared to..maybe a 99 si ecu..besides the extra sensors that the ecu looks for on the 99 ecu's...
thanks...
Old Jun 2, 2009 | 04:31 AM
b16_sol_707's Avatar
Default Re: 96 hatch with jdm b16 and p30 ecu question
exactly the same. you don't need to change anything, you just won't have the obd2 monitors.
Old Jun 2, 2009 | 08:57 PM
autoponicz's Avatar
cool...thanks ..thats good news..i was gonna send it out for a basemap...
Old Jun 2, 2009 | 09:36 PM
Civic VTI-Turbo's Avatar
stay with the stock ecu, if it doesn't trow any cells than you will be fine.
Old Jun 3, 2009 | 01:36 PM
autoponicz's Avatar
i wish it threw a CEL..
the problem is right now the car hesitates/boggs/missfires at under 2000 rpm..1st and
2nd gear will do it.,...then after it gets up to speed... it doesnt do it anymore..
i changed the o2 seonsor and same thing happens...had a master mechanic check the distributor and fuel pressure(thinking it was a clogged fuel filter) and said both is fine....timing is set right...
he said the motor might have some aftermarket camshafts (maybe)...and said i need to rechip the ecu...im wondering if a street tune can find the problem..
im hoping someone has this similar issue to give me some ideas..
also the ecu i got has(converted-good) written on it..what does that mean..
thanks for all the help..
Old Jun 3, 2009 | 07:10 PM
autoponicz's Avatar
super jdm yo
10
Feb 10, 2009 06:58 AM
mky300
Oct 8, 2007 07:42 AM
EK 2 9K
Jan 2, 2007 08:42 PM
