sunroof Help
Old May 28, 2009 | 10:30 AM
d4rk13l4de's Avatar
Default sunroof Help
i have a 93 dx coupe and i have a sunroof on it and my question is, is the an adjustment for the seals or something because my sunroof leaks what it rains and ive searched and i cant find a replacment seal or anything. any help would be great.
Old May 28, 2009 | 11:36 AM
ej1love's Avatar
Default Re: sunroof Help
find out wat kind of aftermarket sunroof it is...
Old May 28, 2009 | 12:40 PM
d4rk13l4de's Avatar
its oem
Old May 28, 2009 | 12:44 PM
rick_rabies's Avatar
I'm not Rick!
search for a new seal for an ex sunroof. or get that carbon fiber roof that bolts right up...
Old May 28, 2009 | 02:42 PM
alsshop88's Avatar
New User
There should be shims where it bolts onto the track see if u can adjust them. Thats what i had to do with my ek. they sell the shims at a honda dealer if u need more.
Old May 28, 2009 | 03:03 PM
d4rk13l4de's Avatar
ill have to take a look tomorrow when it stops raining, it making my headliner all wet. would honda have new weatherstipping and seals?
Old May 28, 2009 | 03:08 PM
alsshop88's Avatar
New User
i dont think so when i got my car my moon roof was shattered so i had to replace the whole thing not just the glass but u can check go to bkhondaparts.com they have a break down of ur car
Old May 29, 2009 | 11:41 AM
ej1love's Avatar
Originally Posted by d4rk13l4de
its oem
k, so you put an one in a dx? you can take the seals off and re silicone them. thats wat i did; and clean the tracks. but it might just have to be adjusted.
Old May 29, 2009 | 08:55 PM
d4rk13l4de's Avatar
i didnt but it is a stock option is it not?
d4rk13l4de's Avatar
it doesnt have tracks, i guess you would call it a moon roof then?
Old May 30, 2009 | 11:46 AM
ej1love's Avatar
ex has sunroof oem. dx, ah not so much. not even option cause it would be like the ex anyway, right?...idk but does it sit into the roof level? does it move when u close the doors? thats wat mine did when it leaked cause it wasnt all the way down.
Old Jun 1, 2009 | 11:44 PM
alsshop88's Avatar
New User
yeah it should sit pretty much flush but there should be drains to help divert the water
Old Jun 2, 2009 | 12:14 AM
NOFX's Avatar
H-T White Ops
its oem
No, it was not an option.
EX and Si had sunroofs. Other trims did not. For '92-'00 Civics in the US it's either a yes or no for each trim. None had it as an option. They were either standard with or standard without for each trim.
Can you take a photo of the sunroof for us? This can help us know if it's really stock or not.
A stock moonroof can be installed in a car that didn't come with one originally, but it's a lot of work. The entire roof has to be cut out and replaced for those cars.
I would suspect clogged drain tubes or possibly a seal. For stock moonroofs I would lean towards the drain tubes first.
Old Jun 2, 2009 | 12:37 AM
amtheiceman's Avatar
the only factory sunroof equiped civic 92-95 is the si model hatch and the ex model for coupes and sedans
Old Jun 12, 2009 | 06:21 PM
d4rk13l4de's Avatar
well here are the pictures, this thing is really leaking now even after i cleaned the weatherstripping, i think i need new weather stripping. but have no idea where to buy it from
Old Jun 12, 2009 | 06:30 PM
NOFX's Avatar
H-T White Ops
That's aftermarket.
A stock Honda moonroof (at least from about 1990 and up) has a rubber seal on the glass and no seal on the roof skin. The roof skin folds inward to the car instead.
Aftermarket moonroofs and sunroofs have a seal on the roof skin because the installers just cut a hole in the roof and it has to be protected by something.
You'll probably have difficulty finding a replacement seal. See if you can find any names or numbers or such on it. You might be able to figure out who made the kit and order a replacement seal from them.
Old Jun 12, 2009 | 06:46 PM
d4rk13l4de's Avatar
i did find the one shop up here in anchorage that installed it, i seen that it was aftermarket when i looked up the only name on there, blindex and it came up with donmar sunroofs and there is only one place up here that installs them, so i will be taking it there when they call me back. thanks for all your help NOFX you are a true asset the the community!
choofy
May 20, 2019 09:15 AM
rwlangdale
May 27, 2015 11:52 AM
project91crxsi
30
Apr 24, 2012 11:43 PM
amount
Jan 19, 2010 05:40 AM
