Bullseye power turbo on a D
Old May 28, 2009 | 06:39 AM
evokidvii's Avatar
Default Bullseye power turbo on a D
Hey im looking for a BW unit for my D, Set up is as follows:
benson sleeves, Laskey built
CP pistons 76mm
eagle rods
Portflow Port and Polish
Bisi 1.2 turbo cam, and cam gear
3inch turbo back custom exhaust
mini ram mani w/ tial 38mm
Bout sums up the set up.
I need a turbo that is going to be good for 500-550#, but also decent on the street, will be running low boost while on the street. I have been recomended by Dan at bullseye to go with the 259 with the 70 ar, and i have also been recomended by a reputable D-series guy to go with either the 362 or 262.
I am just looking for more opinions on this.
Thank you.
Old May 28, 2009 | 09:56 AM
TheShodan's Avatar
Moderator
Default Re: Bullseye power turbo on a D
Decent "spool" is going to be tough with that application. Find out what is more important for you. But I would still say that S259 would be the best bet over the S362 for what you're looking for. Done those on a regular basis.
Old May 28, 2009 | 10:14 AM
evokidvii's Avatar
what kinda of spool times would i be looking at with the 259? As of right now my GT2871R .86 ar i get full boost around 5200-5500.
Old May 28, 2009 | 09:10 PM
ScorpionT's Avatar
The S259 is definitely a better choice. If you didnt mind running higher boost, you could probably get away with something like the S257.
Old May 28, 2009 | 09:34 PM
LurkerS8's Avatar
Get the GT3076 .82 equivalent, I run a GT3076R .82 and hit full spool by 5k and i'm making 475whp right now.
Old May 29, 2009 | 04:37 AM
evokidvii's Avatar
does anyone have a compressor map for the 259? or is it the same as the 258?
also what can you guys tell me about the 262?
Old May 29, 2009 | 06:28 AM
ScorpionT's Avatar
http://www.bullseyepower.com/S200.asp
The 59mm compressor replaced the 58mm if I remember correctly. The S262 would be basically a 62mm compressor matched with one of the smaller turbines, not a good combo.
Aradin
Apr 18, 2012 03:30 PM
uberhaulin
Mar 7, 2007 06:19 PM
AJxr
Dec 9, 2006 02:17 PM
Mr.Hankey
Aug 25, 2006 10:56 PM
92 CIVIC HATCH VX
Oct 21, 2005 09:24 PM
