GSR pistons too tight, any opinions?
Old May 27, 2009 | 10:45 AM
davenport517's Avatar
Default GSR pistons too tight, any opinions?
Hi I am currently building a high comp gsr, Im using 12.5:1 pistons on stock rods and gave them to a shop to have the old ones removed and new ones pressed on. Problem is 3 of the pistons move freely on the wrist pins like they should, the last one doesnt. It moves but it just feels kinda tight, iv tried chucking a load of oil over it and wiggling it around but that hasnt helped. Should I take it back to the shop or is this normal? any ideas would be good....
Old May 27, 2009 | 11:02 AM
98civdx's Avatar
Master Detailer
Default Re: GSR pistons too tight, any opinions?
id take it back to the shop. it should move like all the others.
Old May 27, 2009 | 11:54 AM
jdm_Jim's Avatar
how are you using 12:5:1 pistons on stock rods?
Old May 27, 2009 | 12:15 PM
98civdx's Avatar
Master Detailer
x2 i always thought you had to have aftermarket rods with pistons
Old May 27, 2009 | 12:19 PM
redlinetuning's Avatar
wrist pins have to be fitted properly. The piston/wrist pin clearances have to be checked. If it's too loose or too tight, you'll have issues. Highly recommended that you use aftermarket rods. Eagle or manley rods are commonly used.
Old May 27, 2009 | 12:23 PM
99civicsiguy's Avatar
^x2
Old May 27, 2009 | 08:52 PM
hmm well there jus ycp's of ebay, kinda doing the build on a budget. doesnt sound as though the shop will be able to do anything if i return them then?
Old May 28, 2009 | 08:38 AM
how about getting them to press the old wrist pi into it? I just dont see what getting new conrods is gonna do as its the pin which is too big
Old May 28, 2009 | 10:30 AM
bump could there be some crap caught up in there? ie would it be worth going to the shop and getting him to clean it all up and do it again? some1 has to have had this problem at some point
Vagitarian
Sep 14, 2012 02:14 PM
Honda Sport
Jan 14, 2004 08:19 AM
AzN_Flava
Oct 25, 2002 11:17 AM
