Vtec solenoid gasket
Old May 26, 2009 | 11:19 AM
Lightsped's Avatar
Default Vtec solenoid gasket
I am getting ready to install a new Vtec solenoid gasket on my 00 Si. Do I need to apply any gasket sealer or similar products to this small thin gasket?
Old May 26, 2009 | 11:26 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: Vtec solenoid gasket
no, but its a good idea for a tiny bit of black rtv glue(gasket glue) thats what i put on alot of stuff
Old May 26, 2009 | 01:33 PM
98civdx's Avatar
Master Detailer
i would,
but its not neccasary.
Old May 26, 2009 | 02:56 PM
g230sport's Avatar
where did you get the gasket? guys at work keep telling me they had to buy the whole assembly for like 160 bucks or something.
i know i can buy the gasket, but where...
John
Old May 26, 2009 | 03:09 PM
NACvicSi's Avatar
Honda Bond FTW. It's cheap, it works, and you'd be a fool not to.
John
Honduh
Old May 26, 2009 | 03:51 PM
BryanM.'s Avatar
Resident Gearhead
John
That is bogus information.
Here is the VTEC solenoid gasket (Honda calls it "Spool Valve Filter Assembly") for a '99-'00 Si, because you didn'y say what car you have.
#12:
http://www.hondaautomotiveparts.com/...28DOHC+VTEC%29
Old May 26, 2009 | 03:53 PM
BryanM.'s Avatar
Resident Gearhead
Also, to my knowledge, Honda is the only one that sells them.
Old May 26, 2009 | 04:12 PM
1992Si's Avatar
NO gasket sealer of any kind. Make sure both surfaces are clean, then install the Spool valve gasket and put the solenoid on.
Old May 27, 2009 | 12:14 AM
NACvicSi's Avatar
And why is that? It's dumb not to. You don't put Honda bond on the gasket you put it on the metal to metal surface.
Old May 27, 2009 | 06:33 AM
I'm not Rick!
dont use anything and just see what happens
Old May 27, 2009 | 06:43 AM
ApexiChild's Avatar
the gasket is really thick... i just did it on mine.
it was $13 at honda (got a discount)
no need to use any seal. Hand tighten (25 lbs or so) it and check for leaks...
Old May 27, 2009 | 06:48 AM
redlinetuning's Avatar
no, you don't need to use Honda bond. The gasket is already there.
Old May 27, 2009 | 02:20 PM
NACvicSi's Avatar
Really? So no need to use it on water pump, oil pump, valve cover gasket, spark plug seals, etc etc because the seal is there? It takes 5 sec, uber cheap, and offers added protection. If you don't do it you are retarded.
Moi Zver' (GSR)
Dec 3, 2009 01:17 PM
Lightsped
Sep 1, 2009 08:40 AM
Rok_Stok
20
Feb 18, 2009 08:34 AM
o0ohaviko0o
Apr 14, 2008 07:09 AM
I got a honda
Aug 28, 2005 11:37 PM
