Can I use Hondabond on VTEC solenoid gasket?
Old 02-14-2009, 02:14 PM
Rok_Stok's Avatar
Default Can I use Hondabond on VTEC solenoid gasket?
I have a small oil leak there and want to know if using Hondabond is okay. This would save me from ordering new solenoid gaskets since I already have the Hondabond.
Old 02-14-2009, 02:20 PM
TheRappist's Avatar
Default Re: Can I use Hondabond on VTEC solenoid gasket?
Get the gasket. Don't half *** your car.
Old 02-14-2009, 03:24 PM
Rok_Stok's Avatar
Well I usually don't. I just had a full 180k service done at Honda last summer. But would this be okay in the meantime until I can afford new gaskets?
Old 02-14-2009, 03:55 PM
tx_ej8_49's Avatar
Are you SURE it at the solenoid and maybe not the distributor o-ring, or the valve cover gasket, or even maybe some serious blow-by?
And yea..i think the gasket is not much more than hondabond...Just do it right.
Old 02-14-2009, 05:11 PM
Vietnamese!
ALLxMOTOR EG's Avatar
Do it right the first time.
Old 02-14-2009, 05:48 PM
Meoshe's Avatar
It's actually a gasket with a filter built in. I just replaced mine.
Old 02-14-2009, 05:59 PM
Pabs626's Avatar
cheap skate
Old 02-14-2009, 07:06 PM
yoontim23's Avatar
Not sure about the hondabond, but the Gasket is only like $17 bucks at HONDA.
Old 02-14-2009, 08:34 PM
Rok_Stok's Avatar
Guys, I know I need a gasket. I already placed the o-ring and valve cover gasket. There is oil coming from the VTEC solenoid. Now, the question was can I use Hondabond for a little while or not? Do you guys have answers or just like saying "do it right you cheap skate?"
Only $17 is more than I have right now and the closest Honda dealership is an hour away.
Oh, and I've read a thread where they replaced the solenoid gasket and it still leaked. I don't know why I asked.
Old 02-14-2009, 08:39 PM
2k_Si's Avatar
Maybe its your cam seal
Old 02-14-2009, 09:01 PM
TheRappist's Avatar
www.myhondapartsstore.com
Old 02-14-2009, 09:41 PM
teamworxek9's Avatar
What engine do you have? honda bond is more for flat surfaces not where a rubber gasket is needed.
Old 02-15-2009, 12:34 PM
Rok_Stok's Avatar
That was replaced already as well in the 180k service, and is on the other side of the engine.
Original D16Z6. I'm going to go unbolt the solenoid and see what's up.
Old 02-15-2009, 01:32 PM
BuiltforSin's Avatar
Get the gasket go cheap.
Old 02-15-2009, 02:57 PM
Rok_Stok's Avatar
lol
Old 02-15-2009, 03:09 PM
beana's Avatar
NO DO NOT USE ANY KIND OF SILICONE TO REPLACE ANY GASKET
much less the vtec spool valve, 2 reasons:
#1: it's just plain dumb
#2: if you use to much the excess can get caught in the oil passages and cause untold damage
stick with the gasket, it's only three bucks at your local honda dealership
Old 02-15-2009, 03:56 PM
Master Detailer
98civdx's Avatar
just go on ebay and find one.
honda will ship parts to you.
no do not use hondabond on it.
Old 02-15-2009, 06:45 PM
Rok_Stok's Avatar
I want going to replace the gasket with Hondabond, just use a little on the edges like you would on a valve cover gasket. not IN the freakin oil passage, just where the flanges meet.
Old 02-16-2009, 12:12 AM
trustdestruction's Avatar
just buy the damn gasket
the old gasket would work better than hondabond
Old 02-16-2009, 02:02 AM
mRek9R's Avatar
For temporary, yes...it'll work, but i'd give time to let the hondabond cure before even driving. And by temporary I mean for only a couple of days...if even...max a week. Then get a new gasket, clean the surface off and reinstall!! 8)
Old 02-18-2009, 08:34 AM
Rok_Stok's Avatar
Well there are two gaskets. The upper where the solenoid bolts to the lower filter portion, and the one that seals on the head with the mesh filter. Putting Hondabond on the upper portion could work because you have a lot of flange to work with.
BUT
The consensus is that no Hondabond whatsoever should be used on any part of the VTEC solenoid, even in conjunction with the gaskets. Honda made these gaskets to be able to seal oil on their own. Mine are old, and the top one is brittle and cracking. So I'll dish out the money and get some new ones.
airikkCRX
01-25-2024 03:11 PM
drsab2000
03-25-2014 06:05 AM
supertace91
10-26-2013 12:56 AM
Lightsped
12
05-27-2009 02:20 PM
BlueLude84
02-04-2007 11:14 AM
Quick Reply: Can I use Hondabond on VTEC solenoid gasket?
