new throttle body, new idle issue
Old May 24, 2009 | 09:29 AM
mistahmac's Avatar
Default new throttle body, new idle issue
i just got a gsr throttle body from Ahknodd on the forum. now im having issues with the idle. It idles really high like at 1500-1800. I tried bleeding the cooling system and playing with the idle screw valve. Don't worry guys i think i did it the right way by unplugging the IACV then adjusting. I did notice something different on the throttle body. it was missing a nipple on the top of the throttle body. I had a z6 TB on there before and it had a nipple on top. the gsr one doesn't have one. I currently blocked off the coolant line from the manifold which is supposed to goto the TB. Is this the problem? help me out guys.
Old May 24, 2009 | 11:30 AM
civic_driver's Avatar
Default Re: new throttle body, new idle issue
Could be a problem with the TPS. Check the resistance/voltage and see if it's correct.
Old May 26, 2009 | 12:59 PM
mistahmac's Avatar
checked the TPS and reading correct voltage. im going to do the PCV valve tomorrow. see how it goes.
Old May 26, 2009 | 01:38 PM
JimDCXC's Avatar
Does it bounce from 1500 to 1800 or just stay there? Is it all the time or infrequently? I had a Y8 throttle body that would just stick a little bit. I cleaned the butterfly with some degreaser and no problems since.
Old May 26, 2009 | 01:47 PM
omgwtfbbq's Avatar
Since you don't have the nipple on the TB, then you have a vacuum line that is unplugged (since your car, im guessing is OBD1, the old TB had a vaccuum line on there, pre TB for the EVAP system, and OBD2 TB's don't have that vacuum nipple). Vacuum leaks cause high idle.
Cap the vacuum line, or Tee it into another. should take care of the idle problem.
Old May 26, 2009 | 02:07 PM
Devious951's Avatar
when you rev it up does it at anytime feel and sound like you have LAUNCH CONTROLL?
Old May 27, 2009 | 09:40 AM
mistahmac's Avatar
the idle is nice and steady at around 1400. sometimes to idles perfect at like ~900 rpm when i first start the car. as i drive, the idle is at ~1400. the engine is a y7 OBDII with a z6 manifold, gsr TB OBDII. the line i blocked off is a coolant line from the manifold.
Old May 27, 2009 | 01:25 PM
Former User's Avatar
In addition to the IACV, does the throttle body also have a fast idle valve? Does the disconnected coolant line go to the IACV?
Old May 27, 2009 | 10:48 PM
mistahmac's Avatar
yes the TB has a fast idle valve. the coolant line doesn't go to the iacv. I already have two coolant lines goinging to that. maybe I have them mixed up? but then i still would have one disconnected. 3 hoses 2 holes...lol kinda like 2 girls 1 cup.
Old May 28, 2009 | 07:11 AM
mistahmac's Avatar
idle is all messed up. forget this. switching back to z6 TB
Old May 28, 2009 | 07:14 AM
Does the disconnected coolant hose go to the FITV?
Old May 28, 2009 | 10:47 AM
mistahmac's Avatar
the coolant hose off the manifold is blocked off. Does it goto the FITV? if so which one?
Old May 28, 2009 | 10:57 AM
Maybe the diagram below showing coolant hoses for the D16Z6 engine will help. The IACV (EACV) and FITV are connected by one hose, whereas the other two hoses are for coolant input and output through both valves.
Old May 28, 2009 | 11:04 AM
Khoald's Avatar
almost sounds like a cracked manifold or vacuum leak a buddy of mine did his own without my help and cracked it on the corner and didn't notice it take some spray and you should be able to find it if all else fails i seen alot of replies that i didn't read
Old May 28, 2009 | 02:18 PM
mistahmac's Avatar
guess what guys. now the damn thing doesn't want to start and idle. it now starts for like 5 second rough then dies upon idle or throttle. wtf is going on.
Dannyx321
Oct 17, 2011 05:40 PM
bmxfelon420
Mar 20, 2010 04:11 PM
95_red_dc
Sep 11, 2006 09:47 PM
smkngsr
May 9, 2005 07:06 AM
Initial DA6
Aug 29, 2002 03:24 PM
