RMF Replica 4 -1 Narrow B-Series Header Install and review
Old May 23, 2009 | 08:19 AM
supra360's Avatar
Default delete
delete
Old May 23, 2009 | 11:09 AM
digital sol's Avatar
Default Re: RMF Replica 4 -1 Narrow B-Series Header Install and review
i recieved mine as well, its off for coating work now but i think when i get it back im going to have the collector piece modified for a 3" exit "going s/c w/3" exhaust", have the o2 bung relocated to face vertical and another added for the wideband as well as just having the second piece/exit flange welded instead of just usuing those two bolt's, although having it set-up in two piece does make it easier to remove-reinstall
any dyno numbers just yet?
any issues with leaking from the exit flange?
it seems to be have quality welds and fits like a glove', ill be going back to the dyno in a few weeks to retune and check the a/f', ill post results
Old May 23, 2009 | 11:53 AM
CarbonfiberR's Avatar
Nice header!
Old May 23, 2009 | 01:18 PM
steadysupreme's Avatar
Seems like that is extremely close to the fan, and touching too~
Old May 23, 2009 | 01:52 PM
01_ITR's Avatar
get an aftermarket slim fan and your all set, side note you got a bit of rust on the undercarriage of your car...
Old May 23, 2009 | 02:53 PM
97CWITR's Avatar
That's way too close to the fan for my liking!
How much was the header, and who did the exhaust work?
Old May 23, 2009 | 04:55 PM
mojo_jojo77777's Avatar
wrd. I got mine for my R and I really dont like how the collector flange isnt welded.
Old May 24, 2009 | 01:03 AM
BlueIntegraBoy's Avatar
I don't like how the donut needs to be on the test pipe/cat and not on the collector.
Old May 24, 2009 | 05:06 AM
Clerique's Avatar
Interesting comments. I was thinking about ordering one soon and this post answered some of my questions.
One more question though; does it hamper bleeding of the clutch slave cylinder?
Old May 24, 2009 | 09:16 AM
soulassassin13's Avatar
Well, the welds match the header... they are both ugly as ****. I would have waited for install until I got some thinner fans. GL explaining your fan shroud to the next owner.
Old May 24, 2009 | 09:59 AM
itr1244's Avatar
it would be better if it had merge collector
Old May 24, 2009 | 01:54 PM
supra360's Avatar
Nope it's not touching the bleeder, its like 12mm away.
Old May 24, 2009 | 03:15 PM
^really? cuz my header is extremely close to my bleeder valve. as in, if I wanted to bleed the system, I'd be kinda tricky to do it
Old May 24, 2009 | 10:54 PM
IamVtec's Avatar
does this header fit with the a/c fan too?
Old May 25, 2009 | 06:58 AM
OH_1fstgsr's Avatar
Is there a before and after dyno yet?
Just want to know how much power is a "- Noticeable power gain".
Old May 25, 2009 | 02:36 PM
allmotorek4's Avatar
i trim my fan ... but when you drive it the fan blades get push back more towards that headers more ... mines just nicely molded and shape to the headers after a drive ....
Old May 25, 2009 | 02:39 PM
crazydominicanman's Avatar
Very nice! Hope to run this header as well
Old May 25, 2009 | 02:40 PM
lol a 50 dollar fan? wow itr guys are ****, but if so you **** why buy a knock off header for your car??? it kinda like rolling an itr and shopping at wal mart
Old May 25, 2009 | 06:11 PM
The design of that header does have replica written all over it. My header cost 1330USD, how much was that non fitting POS.
Old May 25, 2009 | 07:38 PM
mine fit's fine....yes it requires a trim to the fan..most headers do require this, you can still keep the flywheel cover without modification' or a slim fan eliminates any issue with the fan
notching the stock fan or going to a slim fan is required for alot of aftermarket header's, i dont see the problem
personally havnt tested this header on a dyno yet but from all the dyno's ive seen this header made more power > any tri-y design', im looking forward to seeing how it peforms and will dyno very soon, time will tell
Old May 26, 2009 | 02:01 PM
supra360's Avatar
sorry no Dyno..
Old May 27, 2009 | 09:48 AM
integratyper1990's Avatar
yeah these headers work beautifully i used a magnflow highflow cat but before that for good measure i put in a flex pipe and after that a stock jdm type r exhaust it sounds nice not to loud and just enough for a good sound havent had a problem with it yet had it for about 3 months mine was all welded on i cut the collector off just to the point where the o2 sensor .
i read up on these before and they were saying these headers are meant for people who want to keep there ac but if you want to install this you have to put skinny fans fal makes them the price is about 350 i got them and they clear the header perfect
tigasTT
Aug 6, 2015 05:38 AM
EM2ABOO
Honda Civic (2001 - 2005)
Oct 25, 2009 10:07 AM
Sean Juan
Welding / Fabrication
14
Jul 5, 2005 11:30 PM
RallyRedGT-V6
May 11, 2004 02:13 PM
typeRicer hater
Jan 21, 2003 07:17 PM
