Blox Throttle boie problems
Old May 23, 2009 | 06:19 AM
Devious951's Avatar
Icon6 Blox Throttle boie problems
I just installed a Blox 68mm Throttle bodie on my 2000 Civic Si. Now after the install i've been getting power suges and Check engine and SRS. I pulled the code and P1129 came out. "Manifold Absolute Pressure (MAP) Sensor Circuit Higher Than Expected Comprehensive."
What does this mean? And how would i go about fixing this? Only mods i have dont to the car are Intake and cat back exaust. plz help =/
Old May 23, 2009 | 12:15 PM
solo227's Avatar
Default Re: Blox Throttle boie problems
well clearly its the map sensor... Did you try resetting the ECU? Sounds like the ECU isnt use to reading the extra air coming into the intake...
Old May 24, 2009 | 12:12 PM
Devious951's Avatar
no i havent dont that. Im going to try to do that right now
Old May 24, 2009 | 12:43 PM
Devious951's Avatar
i reset the ECU but im still having the same problem
Old May 24, 2009 | 11:58 PM
hondaman1320's Avatar
Do you have MAP and TPS hooked up backwards? try switching them!
Old May 25, 2009 | 12:42 AM
BMacls's Avatar
that or the oring is gone or damaged. did you transfor the oring w/map sensor to the new TB?
Old May 26, 2009 | 02:04 PM
Devious951's Avatar
Nope my dumb butt didnt. i looked at it again and saw that that dang o-ring wasnt there =(
Old Jun 4, 2009 | 11:01 PM
BMacls's Avatar
no problem that was easy... glad i could help hows the car driving?
Old Jun 5, 2009 | 08:25 AM
waaBAAH's Avatar
if the ECU detectes low vaccuum aroudn 15 or so it could set off the map code even though the map is good.
glad OP got it fix't
Dc_Ek
Feb 13, 2013 11:47 PM
idriveahonda
Sep 22, 2011 02:06 PM
crfr230
Apr 20, 2007 05:12 PM
JR Integra
Jan 23, 2004 08:48 PM
thashadow
Jun 12, 2002 11:35 AM
