gsr rear sway bar install on a 99 civic ex
do the end links from a 2000 spec gsr fit a 1999 civic ex, i know the si ones do but do the gsr? want to get the gsr sway bar so let me know if the end links will fit thanks.
so i need the si endlinks and the d brackets? Do I need the brackets that go behind then. in the picture it would be part 30
http://www.hondapartscheap.com/south...ARM&vinsrch=no
so please correct me if im wrong. I already have the gsr sway bar, so all that I need is si endlinks or blox adjustable endlinks, then all i need is two of part number 28 and 29, and also part 35 witch is the screws and bolts. But I do not need part #30? also can i use part number 29 witch is the bushing for the 13mm si sway bar for the gsr sway bar because it is only a 1mm difference, or do i need to get the gsr one? thanks in advance.
oh this is where i got the part numbers from.
http://www.hondapartscheap.com/south...t=0&quantity=0
All you'll need are the Si endlinks, the brackets/bushings/screws off the GSR sway bar fits. I have a GSR 14mm rear sway bar on my 99 Civic ex as well.
Its def. a upgrade for the 96-00 civic's that dont have a rear sway. I felt a good noticable difference on the streets and felt a huge difference during canyon running. I'm paired with stiff spring rates as well so the difference was almost night and day.
Does anyone know if you need to upgrade the rear LCA on a 99 civic ex to fit say a 22mm rear sway bar. Or can u use the oem ones? Cause i keep hearing diffrent awnsers.
kensei
Mar 9, 2009 05:17 AM
