Idling Issues
Old May 22, 2009 | 08:45 PM
d_EG COUPE's Avatar
Default Idling Issues
i was wondering if it could be my EGR valve. i mean it only idles when its warm up and its throwing a 12 on the cel. could that be it?
its a 93 si.
d16z6
stock
Old May 22, 2009 | 08:51 PM
94lsrhd's Avatar
Default Re: Idling Issues
Im not sure if it would cause a cel but i know it will cause a idle problem. Check your pcv valve.
Old May 22, 2009 | 08:59 PM
d_EG COUPE's Avatar
the lil plastic thing that sticks to the manifold right near the ports?
Old May 24, 2009 | 12:09 AM
d_EG COUPE's Avatar
uhm?
Old May 24, 2009 | 02:32 AM
shytdoode's Avatar
iac valve? i have a similar problem
Old May 24, 2009 | 05:22 AM
civic_driver's Avatar
Yes, that's the PCV valve.
Old May 24, 2009 | 06:12 AM
Laz's EP's Avatar
What is it that it idles low until it warms up??? If so I'm having the same problem, I dont have my pcv conected, can this be the problem??? Im going to try to connect it and if it works I'll let you know. BTW I have a B16A2
Old May 24, 2009 | 06:43 AM
Former User's Avatar
Yes, code 12 for a fault in the EGR system can cause a rough idle. Definitely fix that code.
Also clean the FITV on the throttle body.
Old May 30, 2009 | 01:13 PM
d_EG COUPE's Avatar
how do i clean it? and wats the FITV
Old May 30, 2009 | 01:59 PM
FITV is Fast Idle Thermo Valve. You remove it, open it up, and clean it with Carborator Cleaner. It can also be adjusted but that's if you have a hunting idle (reving up then down then up again and so on).
Old May 31, 2009 | 06:15 PM
d_EG COUPE's Avatar
man im ajuss take out all my valves and clean em lol
Old May 31, 2009 | 07:12 PM
d_EG COUPE's Avatar
how do i take out the iac valve? i mean do i gotta take off the manifold or...
d_EG COUPE's Avatar
how do i fix it though?
Old May 31, 2009 | 07:29 PM
bbsprelude's Avatar
IAC is a code 14, do you have both codes? you can try to clean the EGR, but would probably be better to replace it
Old Jun 1, 2009 | 09:30 PM
d_EG COUPE's Avatar
im havin a rough idle. but 12 bein thrown up.
Old Jun 1, 2009 | 09:31 PM
d_EG COUPE's Avatar
idk
Old Jun 1, 2009 | 09:43 PM
d_EG COUPE's Avatar
so how can i clean the egr?
Old Jun 1, 2009 | 09:45 PM
Old Jun 1, 2009 | 09:56 PM
d_EG COUPE's Avatar
wooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooow! thanx lol seems like a days work haha
Old Jun 21, 2009 | 07:02 PM
B16a_95_cIvIc's Avatar
good info bro
JBirch_97Prelude
Mar 26, 2007 08:43 AM
k_lude
Mar 24, 2007 12:53 AM
r1de4life
Jan 14, 2006 03:49 PM
Ricey McRicerton
Mar 19, 2004 09:11 AM
