going boost best option?
Old May 21, 2009 | 04:29 PM
Ef9REX's Avatar
Default going boost best option?
I have a 91 rex si right now a6 motor but just picked up full built z6 head.. i wanna know the best combo for boost...i want it to be a dd but want to put out 300hp..already have vitara pistons for block...INPUT PLEASE
Old May 21, 2009 | 05:05 PM
D16SiHatch's Avatar
Default Re: going boost best option?
Better get some eagle or pauwter rods, as well as arp rod bolts and head studs.
Old May 21, 2009 | 05:32 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Better get a tune also.
Old May 21, 2009 | 06:15 PM
jhammond_82's Avatar
Reject Papi
thats a good start there. don't forget fuel injectors. you can use eclipse/talon turbo injectors. they are 450 cc. there is a thread in the forced induction forum for turbo sohcs. you could go there and check out everyone's set up and decide what you would like to do. also having a set budget in mind would help too.
Old May 21, 2009 | 06:45 PM
Ef9REX's Avatar
thanks guyz appreciate the info
Old May 21, 2009 | 06:47 PM
Ef9REX's Avatar
sorry failed to mention i already have rods also..my porblem is deciding what block to use...i have an a6 right now w/the z6 built head is that a good combo for boost before i go any further
Old May 21, 2009 | 07:01 PM
Reject Papi
that block will do just fine for a build. the z6 blocks, from what i've seen are actually the block of choice. i've got a friend that puts 450 hp to the ground using a z6 block, fully built of course.
Old May 22, 2009 | 07:43 AM
Ef9REX's Avatar
thanx dude
Old May 22, 2009 | 07:55 AM
1kleenef's Avatar
Would this happen to be Hawbakers?
slammedNslowLS
Jul 30, 2009 09:04 PM
eg4usdm
May 2, 2005 07:01 PM
MUGENTYPER
Mar 26, 2003 08:30 AM
98civicEX
Dec 19, 2002 02:44 PM
