OBD2B distributor to OBD2A engine harness
Old May 21, 2009 | 09:51 AM
ondenoantra's Avatar
Default OBD2B distributor to OBD2A engine harness
ok im using a obd2b distributor with a obd2a engine harness and i have all the wires hooked up with one left which is the solid dark blue wire which is also the rpm wire. can someone help me find out how to hook this wire up ? thank you in advance
Old May 21, 2009 | 10:41 AM
rick_rabies's Avatar
I'm not Rick!
Default Re: OBD2B distributor to OBD2A engine harness
buy a obd2b dizzy or go to www.rywire.com and buy an adapter, i just bought 1 and its the shiz. he nevers answers your emails though.
Old May 21, 2009 | 10:22 PM
i am using a obd2b dizzy im going from 0bd2b dizzy to obd2a and i checked rywire and found nothing. thanks though anyone else?
Old May 23, 2009 | 04:35 PM
CivicEX13's Avatar
i have the same problem except i m goin obd2a to obd2 b
Old May 23, 2009 | 05:27 PM
CivicSpoon's Avatar
I believe the blue wire is on the inside of the OBD2B distributor, and you just tap into it. Damn, where's 94EG8 with the answer?
Old May 24, 2009 | 04:48 AM
94EG8's Avatar
Seagull Management
Take the distributor cap and rotor off,remove the plastic cover so you can see the igniter,there will be one empty terminal, run a wire from here to the distributor plug.
He's right here
Old May 24, 2009 | 06:06 AM
He's right here
thank you very much guys. and for the person going form obd2a to obd2b and if im correct u have a 99-00 civic you can just leave the wire alone don't have to hook it up to anything because your model year gets the tach from the ecu not the distributor. just search obd2b distributor and you'll find it. once again thanks guys
Old May 24, 2009 | 06:15 AM
xzodiackillerx's Avatar
I have a problem with the plugs
96-97 Del Sol DOHC Dizzy
2000 Civic Dx harness
Old May 24, 2009 | 08:59 AM
mony725's Avatar
Old Oct 17, 2009 | 06:08 PM
killacam661's Avatar
im having the same problem, my harness is a 96 ls and there is no blue wire on the harness, is my 96 ls harness NOT a 96 ls harness??
Old Oct 29, 2025 | 06:37 PM
Ek_Luna's Avatar
Spoiler
BukakkEK9
Oct 15, 2006 01:01 PM
hondakevin21
Apr 21, 2006 11:32 PM
civic00_dude
Mar 3, 2006 07:16 PM
H23vtecEG
Oct 14, 2003 05:02 PM
