OBD2B distributor to OBD2A engine harness
ok im using a obd2b distributor with a obd2a engine harness and i have all the wires hooked up with one left which is the solid dark blue wire which is also the rpm wire. can someone help me find out how to hook this wire up ? thank you in advance
I'm not Rick!
Re: OBD2B distributor to OBD2A engine harness
buy a obd2b dizzy or go to www.rywire.com and buy an adapter, i just bought 1 and its the shiz. he nevers answers your emails though.
I believe the blue wire is on the inside of the OBD2B distributor, and you just tap into it. Damn, where's 94EG8 with the answer?
thank you very much guys. and for the person going form obd2a to obd2b and if im correct u have a 99-00 civic you can just leave the wire alone don't have to hook it up to anything because your model year gets the tach from the ecu not the distributor. just search obd2b distributor and you'll find it. once again thanks guys
BukakkEK9
10-15-2006 01:01 PM
hondakevin21
04-21-2006 11:32 PM
civic00_dude
03-03-2006 07:16 PM
H23vtecEG
10-14-2003 05:02 PM
