Whats wrong with my slave cylinder?!?!
Old May 19, 2009 | 03:55 PM
FRKWOO's Avatar
Default Whats wrong with my slave cylinder?!?!
i recently had to change out my slave cylinder it was leaking and h-t said it might of been a ring out of place but it was cheap to replace i jus decided to just go with a new one. today i got a new slave cylinder from autozone the fluid line that connects to the slave cylinder from honda and a bottle of dot 3 brake fluid when i got home replaced everything dumped in the new brake fluid my clutch pledal was still super soft and not stiff like how it use to be anyone know what i am doing wrong and how to fix it? thanks h-t!
Old May 19, 2009 | 04:06 PM
BryanM.'s Avatar
Resident Gearhead
Default Re: Whats wrong with my slave cylinder?!?!
Did you bleed the line?
Old May 19, 2009 | 04:07 PM
FRKWOO's Avatar
yes i did
Old May 19, 2009 | 04:08 PM
thi3v3z's Avatar
Bleed the line, and it might be the master cylinder.
FRKWOO's Avatar
after i took of the old slave cylinder and the line connected to it i pumped the clutch pedal until all the fluid was out of the resivor
Old May 19, 2009 | 04:11 PM
thi3v3z's Avatar
Well that means you got air in your master cylinder. You NEVER want the reservoir to get low.
BryanM.'s Avatar
Resident Gearhead
Did you then fill the reservoir and bleed out the air, topping the off the fluid in the reservoir as you bled?
Old May 19, 2009 | 04:14 PM
thi3v3z's Avatar
Heres a thread to check out, it will go through pretty much all the diagnosing, and will give you a good idea how to bleed a system properly.
https://honda-tech.com/forums/showth...lutch+problems
Old May 19, 2009 | 04:15 PM
FRKWOO's Avatar
i was by myself so i filled the reservior then pumped it then closed the bleeding valve what should i do to fix this?
Old May 19, 2009 | 04:17 PM
thi3v3z's Avatar
Well you should really have two people, one to make sure air is coming out, and the other to control the clutch pedal.
Old May 19, 2009 | 04:18 PM
FRKWOO's Avatar
so what do i do have one pressing the clutch and the other.....?
Old May 19, 2009 | 04:19 PM
thi3v3z's Avatar
read the thread theres a full description to properly bleed.
Old May 19, 2009 | 04:25 PM
shytdoode's Avatar
if u have air in your clutch master cylinder you have to bench bleed it get a tub that connect to the opening of where the fluid comes out leading to the clutch master reservoir and pump until you dont see bubbles then install dont let it get too low on fluid
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
Duck Sauce
Apr 13, 2008 09:30 PM
ludesrv
Jul 17, 2007 03:07 PM
.water
Apr 3, 2006 07:56 AM
ferio 95
Jul 22, 2005 10:03 PM
