1500 start up???
Old May 19, 2009 | 03:01 PM
skipbudlong's Avatar
Default 1500 start up???
I have a b16 hatch and was wondering why it idles at 1500 rpm evrytime the car is cold. Is this normal? How do i get it to start like any other normal car, you know at 1000 rpm. Help me honda geeks.
Old May 19, 2009 | 03:04 PM
crxblues's Avatar
Default Re: 1500 start up???
does it drop down after it warms up?
Old May 19, 2009 | 03:05 PM
yes it does.
Old May 19, 2009 | 03:14 PM
do all first gen b16s do this?
Old May 19, 2009 | 03:30 PM
BoostedZC's Avatar
mine sure does sits about 2000 at start up and after warm up sits 800-900 i have no idea lol i am running 5w30 in it and am gonna try 10w30 see if it helps a bit, so im with ya, anyone else??
Old May 19, 2009 | 04:03 PM
sde780's Avatar
It's supposed to do that. Mine stays at 1500 rpms and drops once it's warmed up. I have a d15b2. All cars do this man
Old May 19, 2009 | 05:12 PM
89s1's Avatar
X2
Old May 19, 2009 | 05:13 PM
jhammond_82's Avatar
Reject Papi
its a honda thing. lol. if the idle is lumpy or drops frequently then it would be time to clean or adjust your fitv. but the way it sounds, its acting normal.
Old May 21, 2009 | 08:55 AM
If its a honda thing then why does my homies eg with a d16 start up normally? Im thinking a switch from obd-0 to 1 will change the cold start, no?
Old May 21, 2009 | 09:01 AM
crxblues's Avatar
maybe his doesnt have a fitv? the fitv is is what causes the engine to idle somewhat hight when its cold.
Old May 21, 2009 | 10:29 AM
Ezarakal's Avatar
My car does this too and its a d16.
Old May 21, 2009 | 10:48 AM
mjfubar101's Avatar
Most cars do this, it is used to help the car warm up. My STI does it as well, its not a honda thing its a car thing
Old May 21, 2009 | 12:33 PM
Hmmmm. Maybe.
Old May 21, 2009 | 12:42 PM
BSeriesRescueteam's Avatar
My SOHC ZC does the same. Idles at 2000 RPM for about 2 or 3 minutes to help bring the engine to normal operating tempratures. After it does that it drops down to 800 RPM. If you were to drive it around for abit and say go into Wal-Mart for 5 minutes or so and grab a fruit punch drink...and walk back out and crank it up..chances are it'll idle at 800 or 1000RPMs. Reason for that is because you were only out of the car for a few minutes and it stayed warm, there for it would not rev high to warm it up.
Old May 21, 2009 | 12:45 PM
supersteven's Avatar
That's completely normal. All 4 Hondas I've owned did that.
Old May 21, 2009 | 12:49 PM
4drEF's Avatar
Keyboard Humorist
D16Y8 swaps don't do that (unless you go OBD-2).
They don't have a FITV.
Old May 21, 2009 | 02:56 PM
Eighty-Nyne's Avatar
Every single car I have ever driven has cold idled at 1500...
Old May 21, 2009 | 02:59 PM
gibsanez's Avatar
What's the big deal? If it's not broken, don't fix it.
Hell, my 86 civic is carb'd and idles at over 2500 in the cold, 1500 would be awesome.
Old May 22, 2009 | 01:31 PM
So this is all because of the fitv, right? Would this cause the rpms to drop low after driving for awhile? It'll be at about 800 to 1000 in the beggining then after a good 20 to 30 min of driving itll rev really low, almost dies. What is that???
Old May 22, 2009 | 01:38 PM
Reject Papi
maybe your idle needs adjusted then. ^^
Old May 22, 2009 | 06:36 PM
DCRB's Avatar
my van does that, starts at 1500 when cold then drops down to like 800. so does my d15b1 hatch.
Mooster
Jan 8, 2017 11:58 AM
lyzer227
Feb 7, 2009 12:02 PM
delguiner
Sep 25, 2004 01:45 PM
EK45VTi
Jul 30, 2004 03:40 AM
turbo sol
Jan 3, 2004 05:57 AM
