d16z6 obd1 into 99 civic obd2 (ej6) HElP!!!
Old May 19, 2009 | 10:47 AM
stkinge's Avatar
Default d16z6 obd1 into 99 civic obd2 (ej6) HElP!!!
Okay i have a problem. i swapped my d16y7 out of my 99 civic. in its place i put a Z6. My problem is that the engine starts but idles rough after it warms up. It aslo misfires. I have done the following:
ckp bypass trick
3 wire iacv to 2 wire iacv
bled the coolant
checked spark plugs and wires
I think that maybe i didnt connect all the vacuum lines right. As for the misfireing, im going to check my timing. Could someone who has done this swap please post pics of where all the vac lines are connected. all suggestions are apreciated. thanx in advance
Old May 19, 2009 | 10:51 AM
Former User's Avatar
Default Re: d16z6 obd1 into 99 civic obd2 (ej6) HElP!!!
If a vacuum line was not connected, then the idle speed would be high. Are the plug wires and fuel injector connectors plugged in the right order?
I think you should inspect the cap and rotor, and the mechanical and ignition timing.
Is the CEL ON?
Old May 19, 2009 | 10:59 AM
stkinge's Avatar
yes the plug wires are pluged in right. ( number one bieng closest to crank pulley ) as for the injector plugs i am not sure. as for the distributor it was recently rebuilt. and the cel is on .
Old May 19, 2009 | 11:33 AM
Originally Posted by stkinge
...and the cel is on .
What are the codes?
Old May 19, 2009 | 11:46 AM
stkinge's Avatar
they were p1509 idle air control valve circuit fault 2, and the first o2 sensor. i replaced the o2 sensor.
Old May 19, 2009 | 11:56 AM
Others should be able to tell you whether you need a different ECU.
Your IACV wiring seems to be wrong as indicated by the code.
Did replacing the O2 sensor fix the code?
Here's the plug wire order in the distributor cap:
Old Jun 23, 2009 | 04:23 PM
stkinge's Avatar
OK ALL THE SPARK PLUGS WIRES PLUGED IN CORRECTLY. AND THE O2 SENSOR FIXED ONE CODE BUT I STILL THE P1509 CODE FOR THE IACV. I ALSO HAVE A P28 WITH A JUMPER HARNESS BUT WEN I CONNECT IT IT STARTS AND RUNS BUT DIES AFTER A FEW SECONDS. WHY WOULD IT DO THAT??? COME ON GUYS I NEED HELP!!!!
Old Jun 26, 2009 | 08:38 PM
stkinge's Avatar
bump
LuckyStrike90
Aug 2, 2024 12:10 AM
dinko
39
Jul 7, 2023 09:17 PM
bunnyx
Feb 16, 2014 10:10 AM
yek99
Oct 14, 2012 12:04 PM
penance76
Nov 11, 2011 02:21 PM
