Lighting HID/Xenon kits, Retrofits and Associated Topics
can any of you help me i have no low beams
Old May 18, 2009 | 02:48 PM
07jdmfit's Avatar
Default can any of you help me i have no low beams
i own a 2007 honda fit and as of three days ago i lost the low beams , now its high beams or nothing , running lights work tails work just no low beam
Old May 18, 2009 | 04:40 PM
07jdmfit's Avatar
Default Re: can any of you help me i have no low beams
i have heard that i should turn on and off the switch fast and it will come back , i have replaced the light bulbs but no luck so far
Old May 18, 2009 | 06:50 PM
98civdx's Avatar
Master Detailer
check the fuses
Old May 18, 2009 | 07:07 PM
07jdmfit's Avatar
already did no luck , thanks though
Old May 19, 2009 | 05:14 PM
TunerN00b's Avatar
Take it back to the dealer to fix under warranty.
Old May 19, 2009 | 08:30 PM
07jdmfit's Avatar
cars out of warranty think im screwed
Old May 20, 2009 | 12:22 PM
TunerN00b's Avatar
So you checked the fuses already?
Pull the bulbs and check the filament.
Use a multimeter and check for voltage at both sides of the fuse with the lowbeams turned "on" (even if they don't light up). If so, check for voltage at the lamp plugs directly. Check the grounds as well.
You know, do basic troubleshooting on it.
StreetRiot_DRE
Mar 4, 2008 07:16 PM
civic_hatchy
Nov 26, 2004 01:08 PM
PleaseHelp
Oct 8, 2004 05:31 AM
MPF_supra
Apr 16, 2004 10:32 AM
shattergsr
Nov 25, 2002 11:36 AM
