HELP: Turn signals not working
Old Apr 6, 2004 | 10:26 PM
MPF_supra's Avatar
Default HELP: Turn signals not working
ok i'm driving and all of the sudden my turn signals stop working, the interior lights inside the car aren't working either, by that i mean the "CHECK ENGINE LIGHT" and the other small lights, the odometer light still works..than my turn signal stop working all of the sudden, i got no signals at all..i checked all the fuse and they are all fine..can someone help me?
i would appreciate it alot..thank you
-meng
Old Apr 7, 2004 | 07:03 PM
MPF_supra's Avatar
so no one knows what's wrong??
-mpf
Old Apr 7, 2004 | 07:16 PM
Eggman's Avatar
Default Re: (MPF_supra)
make sure your hazard switch is completely off. if it gets stuck between the ON and OFF, it will keep you from using your signals. hth.
Old Apr 7, 2004 | 07:30 PM
dra600n's Avatar
either that, or check the fuses. I just had some issues with my instrument/tail light fuse today
Old Apr 7, 2004 | 07:35 PM
hksbigboi4's Avatar
Default Re: HELP: Turn signals not working (MPF_supra)
it could be a number of things.. bad connections.. maybe a wire is grounding out ..also check the fuse under the hood ..
Old Apr 7, 2004 | 09:08 PM
blackZC (W)
Guest
Posts: n/a
Default Re: HELP: Turn signals not working (hksbigboi4)
blinker fluid needs to be changed
Old Apr 7, 2004 | 11:31 PM
B1TEM3's Avatar
buy an electronic cleaner and spray it on every electrical harness.
inspect all the bulbs, make sure no crack bulb or rust in the housing.
inspect rear tail light for water in the tail light
inspect fuse
if you cant find anything, borrow multi meter and check the voltage on the faulty turn signal. and work your way
Old Apr 16, 2004 | 10:32 AM
jdmknight's Avatar
Default Re: (dra600n)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dra600n &raquo;</TD></TR><TR><TD CLASS="quote">either that, or check the fuses. I just had some issues with my instrument/tail light fuse today</TD></TR></TABLE> didn't you read he checked the fuses
revvhavok
Aug 30, 2009 08:19 AM
nyrican23
May 22, 2009 06:41 PM
myvtechits
Dec 1, 2007 02:47 PM
CaMiKaZi
May 15, 2003 01:27 AM
djtony5
Mar 31, 2003 01:18 PM
