2000 civic with a 96 engine harness wont start
Old May 17, 2009 | 06:49 PM
91daINTEGRAda91's Avatar
Default 2000 civic with a 96 engine harness wont start
i bought a 2000 civic ex and im piecing it together its not getting spark and the fuel pump is not priming and i want to know if its because it has a 96 ex engine harness on it or any other info would help...
Old May 17, 2009 | 07:19 PM
94EG8's Avatar
Seagull Management
Default Re: 2000 civic with a 96 engine harness wont start
'96 - '98 engine harnesses aren't compatible with a '99 - '00 chassis and vice versa. Although IIRC the engine should still run, most of the problems had to do with gauges not functioning.
Old May 19, 2009 | 07:26 PM
i just found out the engine harness is out of a 99 the engine harness has 4 plugs that go into the ecu but the ecu only has 3 spots so i have a green one left over but i dont know where is does any help ppl
Old May 19, 2009 | 07:40 PM
Former User's Avatar
Extra connector = Automatic transmission harness?
No start problem:
Are important ground wires on the thermostat housing and transmission connected?
Old May 19, 2009 | 08:24 PM
R666_EK's Avatar
I heard that the difference is the 99 (obd2b) doesn't have the green plug. It has all the connectors going into the ECU whereas the 96-98 has the 3 for the ECU and the green plug is off to the side. I'm pretty sure some of the wires go to different pins as well. Just get yourself the right harness.
Old May 19, 2009 | 08:51 PM
geneeunit's Avatar
99-00 harness has 2 ecu plugs on the engine harness, and a green connector which connects to the underdash harness which has the 3rd ecu plug.
96-98 harness has 3 ecu plugs on the engine harness, and a green connector to connect to the underdash harness.
if that was confusing, i can take photos of what i mean, i think i still have my obd2a harness somewhere. or i can make you a diagram in paint. lol.
EDIT:: i know theres no sales in these parts of the forums, but i have a 96 underdash harness i dont need.. if that proves to be your problem.
Old May 19, 2009 | 08:54 PM
R666_EK's Avatar
Ahh. Yes thats the difference. I knew the 99 had one less.
Old May 19, 2009 | 08:57 PM
This is what I found in the service manual:
96-98 have 4 ECU connectors (3 gray, 1 blue), but gray connector B is only for AT.
99-00 also have four connectors (3 gray, 1 blue), but none are specifically designated for the AT.
I did not see any green ECU connector for either.
Old May 19, 2009 | 09:05 PM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
The green plug is the dash harness. It plugs into the other green plug that should be somewhere next to the ECU.
Old May 19, 2009 | 09:14 PM
geneeunit's Avatar
yeah, the green connects the engine harness to the underdash harness.
for the 99-00 the A/T connector is connector D i believe (the little one)
Old May 19, 2009 | 09:20 PM
I think you may be right.
Old May 19, 2009 | 09:49 PM
Just-a-hoe's Avatar
96-98 is obd2a
99-00 is obd2b
Just use the right harrness. save the headache. and its not hard to wire vtec if you can't find an ex one. its only 2 wires
Torleif
10
Aug 20, 2015 05:29 AM
da59block
14
Nov 11, 2011 12:33 PM
choua01
Nov 20, 2008 06:55 PM
Namoper
Aug 19, 2008 06:40 AM
tonyxcom
Aug 15, 2002 04:59 AM
