ECM/TCU problem?
Old May 17, 2009 | 08:54 AM
aznlangjai's Avatar
Default ECM/TCU problem?
So I park on a hill the other day and my heater core was leaking coolant already. It flooded the passenger side about 6 inches up towards the ecu. When I tried to start the car, I can hear knocking sound in the shifter as if it's trying to get into gear.
1. So is my ECU computer toasted?
2. How do I check if it's still working?
3. Are they expensive to replace?
4. Will junkyards have these parts?
5. How do I replace it if it's toasted?
Old May 18, 2009 | 04:37 AM
aznlangjai's Avatar
Default Re: ECM/TCU problem?
bump
Old May 18, 2009 | 04:00 PM
bacid's Avatar
- Replacing is very easy, buy from a junkyard for <$100
- Dealer CANNOT test, I found this out when my ECM was acting up.
- Before the replacement ECM will work you will need to have it programmed for your keys.
I don't know if the ECM is the cause of your problem though, you'll have to do some troubleshooting and figure it out.
averyvm
Engine Management and Tuning
Sep 30, 2013 05:36 AM
Zrt1200
Jun 10, 2008 10:22 AM
silverbur
Feb 5, 2008 01:42 PM
JDM EJ1 95
Oct 6, 2005 12:12 PM
Garsis
Jun 6, 2005 01:48 PM
