msd ignition
Old May 16, 2009 | 03:49 PM
prelude182's Avatar
Default msd ignition
can someone point me in the right direction on how to install an msd ignition to my car? i have a 93 ej1 with a mini me swap. ive searched and searched but cant find a write up or anything.
Old May 16, 2009 | 03:53 PM
1992Si's Avatar
Default Re: msd ignition
Save yourself the trouble and leave the OEM set up in there. It's good to way over 400whp.
95% of the racers here will tell you MSD and Honda don't go together well.
Old May 16, 2009 | 05:28 PM
CountDracura's Avatar
1992Si is correct. The stock ignition system sparks just fine for most any swapped Honda. MSD ignition is great for older cars or if you have no ignition to start with, however. If you feel as though you need it, it is a relatively easy install. Do you have just the ignition box?
Old May 16, 2009 | 05:44 PM
DownShiftPerformDC2's Avatar
MSD Has wiring diagrams to help you with the install look on there site.
Old May 16, 2009 | 07:03 PM
prelude182's Avatar
yeah i found the install guide. i just want to try it out for a little bit. its got a 8000 rmp rev limiter so i just want to dink around with it. i understand its not gonna do much for me but it wouldnt hurt to try out on a project car.
Old May 16, 2009 | 07:35 PM
JSPECSIR's Avatar
red and black go to the battery, red and white go to the original coil wires and black and orange go to coil. the diagram is in the install book that comes with the msd box. ive used an msd setup for 6-7 years. coil went bad once, other than that it works fine. i use it to retard my timing for nitrous.
Old May 16, 2009 | 09:41 PM
prelude182's Avatar
i didnt get it brand new. my brother got a ford probe with the msd ignition and he pulled it and gave it to me. so yeah its used but he said it works good. he didnt feel like he needed it and gave it to me because d15 engines can take a beating from my experience.
elusive123
Jun 18, 2005 07:16 PM
lshatchcx18
Mar 10, 2004 10:44 PM
Drum_Guru
Sep 21, 2003 06:58 PM
scrubachu
Sep 26, 2001 11:18 AM
scrubachu
Sep 26, 2001 09:17 AM
